correct jack stand placement.
Roberte
Member
I have a BJ7.
Where are the correct jack stand placements front and rear? Also where are the correct placements for the jack, front and rear to raise both sides into the air?
EV2239
I'd use the axle for the rear and bottom suspension arms for the front. The handbook tells you to put the car jack under the rear spring under the axle at the rear and under the bottom suspension arm front.
The chassis isn't very strong and gets dented if you jack on it.
I have a 2x4 just long enough to reach from chassis rail to chassis rail at the front crossmember (about 18"). I remove the cup/pan from a floor jack, put the 2x4 under the front crossmember and lift it with the flat top of the floor jack; the bulk of the weight of the car is supported by the frame rails, but the 2x4 bends just enough so the crossmember takes some of the load (most crossmembers are damaged from people putting jacks directly under them). Then, I put the pan back on the floor jack and place it under the differential from the passenger (right) side, coming in in front of the right rear wheel at an angle (the exhaust system is in the way on the driver side). Once lifted, I put jackstands under the front A-arms between the bottom trunnion and the spring pan, and under the rear springs on the flat area just behind the pan where the big U-bolts attach. Only some floor jacks are low enough for this--mine is from Harbor Freight many years ago--and I have to lift the front end a little by hand to load the shocks, and at that I can barely get the jack and 2x4 under the chassis. I leave the floor jack just slightly loaded under the diff for extra stability, and it's ready to go when I reverse the process.
Of course, this is on a flat, smooth concrete surface; the car once rode through a Richter 5 earthquake while on jackstands and stayed put.
Keoke
When I want to lift the front end of the car to set Jack stands:
I get the rubber pads that are used on two post floor lifts and add one to the jack pad this allows me to jack the front cross member without damaging it . You must have a known good front cross member though.
bighealeysource
I do it like Bob and Keoke mentioned. I use a 2 x 6 about 2 feet wide under the rear frame cross member and same under the front cross member with a low profile floor jack and works perfect. The wood takes some of the stress off of the steel frame members plus spreads the lift over the 2 feet width.
Keith_M
I use almost exactly the same procedure as Bob described, and I have the same problem with the 2x4 barely clearing the frame. At some point, I would like to take a piece of steel plate about the same size as the 2x4 and weld it to a short piece of steel pipe that will fit in the cup of the jack. I think if I use 3/16 or 1/4 plate (maybe a little thicker?), it will have about the same flex at the 2x4 and distribute the load across the front cross member and the frame rails. The advantage of this would be that it would fit easily under the cross member without lifting the car up.
I sometimes position my front jack stands under the frame rails just about where the rear of the A-arm attaches. My frame is solid, and I wouldn't try this on a frame with significant rust. This also has the disadvantage of letting the front suspension hang, which is bad for the little rubber bumpers under the shock arms.
Patrick67BJ8
Photo of my orginal Front Cross Member before my new Jule Frame. I'm sure that the size of the weld made it hard to split again. Also probably the strogest part of the frame! A photo of my new "tool" for jacking under the Front cross member. It fits into a hydraulic jack and has a post to secure it from sliding or falling off. I have not had to use it yet.
Keith_M
Patrick,
Your tool for lifting at the front cross-member is pretty similar to what I have been contemplating. Out of curiosity, why did you make it so elaborate? I'm thinking a simple steel plate would be sufficient, but maybe I'm wrong...
Keoke
why did you make it so elaborate? I'm thinking a simple steel plate would be sufficient, but maybe I'm wrong...-
YEP:KEITH
You must insure that if the jack walks or the car moves then the plate does not slide off the cross member.
Prolly should have a stop [ LIP ] in front too??---IT Has One!!
Patrick67BJ8
Patrick,
I purchsed mine from a guy who was selling all his left over Healey stuff(he was retiring). There's front AND rear lips to hold it in position plus the rubber liner(to keep it from damaging the paint) and the bottom has the round protrusion to keep it from sliding off the jack. Most jack pads are removable and this is supposed to fit in "that hole". I really didn't think it was elaborate when I purchased it but rather well thought out. I've been working on Healey's since 1970 and have seen plenty of accidents with "cheap jacks" so this seemed to address that plus safety issues. It's thick steel too.
Keith_M
I can see the need for a front and rear lip. What about all the other bracing? I don't see why a single flat plate of steel wouldn't work.
Just trying to save myself unnecessary work. Now that I've seen something like this, I'm inspired to construct my own. :smile:
I have a similar jack saddle that I bought a number of years ago from a guy in Ohio--I think--who made them but is no longer doing so. A welder friend of mine was so enamored with the design that he has made some and offered them to the Healey community for a nominal sum. If anyone is interested send me an email and I will give you his contact info: michael.oritt(at)gmail.com.
I had a 12 inch long, 5 inch wide 1/4 inch thick piece of steel fabricated. There is a one inch high bend forming a "stop". I glued extra carpet to it and mounted it on a hockey puck that fits into the round disc on the HF low profile floor jack. It works well on the cross member on both the front and rear frame. Hockey pucks work well in the jack stands too. They are a very hard rubber that will not effect the paint or frame. You can get them at used sporting goods stores for a buck.
Here's a pretty crappy picture of the jack saddle I mentioned earlier. It was made by Lin Cline of Classic Collectibles--I bought it probably ten years ago. The nice thing about it is that it fits perfectly both the front and rear cross-members and once in place there is no chance of its sliding out of position, etc.
Though it does not show in the photo the saddle has a 1" OD "pin" welded to the bottom surface which fits into the hole in the floor jack when the stock jack saddle is removed. Again this locks everything together and makes it pretty nigh impossible for the car to fall off the jack as I am no longer relying upon friction and gravity to locate the jack under the cross member. The retainer lips along the front and back edges do increase the height of the jack by about 1" but I have no problem using it on my 100 with a standard floor jack.
BTW some time back I purchased a wonderful shop floor jack that has a super low profile and a long reach which I need for the Elva MK IV sportsracer which has ground clearance of only 3-1/2": Pittsburgh (Harbor Freight) two ton "Low Profile--High Lift. It would positively work on the lowest Healeys.
On this subject, do not cover your floor with the rubber mat stuff that stores like Costco sells. Jacks wheels do not roll on it as the car raises and will pull the car off the jack. You do not need to ask how I know.
TH
Patrick67BJ8
Can you get the sku number from the Harbor lift you bought and post it?
Thanks
Keith_M
This is an old thread, but I finally got around to making a simple saddle that fits the front cross member. It's just a piece of 1/4 in steel plate with a lip on the front and back, and a piece of 1.25 in rod on the bottom to fit in the jack. Simple, cheap, easy, and it works fine.
bighealeysource
Hey Keith,
Glad you posted this as after reading the entire thread again, think I will make up something like you did to put on my low profile HF jack ( like Michael Oritt has). Been using a 2 x6 but do have to make sure it is positioned right and the saddle would eliminate getting up and down on my creaky old knees so much.
Thanks
Mike
Keith_M
Hey Keith,
Thanks
Mike
Hi Mike,
If you do make something like this, let me know how it turns out. I made mine just long enough to overlap the frame rails. On my car, the frame rails are a little lower than the crossmember (because of DPOs jacking the car using the crossmember) so the saddle flexes a little to contact both the crossmember and the framerails as you jack the car up. I view this as a positive because it distributes the weight, but I suppose it could be construed as a negative. The 1/4 plate "feels" strong enough to me, but I'm no engineer, and it wouldn't be too hard to add some extra bracing under the plate along the sides to keep it from flexing.
Keith
RDKeysor
Bronze
I just recently learned why the manual recommends placing the jack under the A arm (under the front coil spring). Typically, I lift the front with a piece of thick rubber industrial belting atop the jack's pan and a three or four-inch wide piece of wood between that and the frame. I do this on both sides, then add the jack stands. This, of course, allows the wheel spindles, etc., to hang, nicely crushing the rubber buffer rebound (Moss terminology for part 031-279). There is one of each on either side. I just did that, fortunately having ordered the two buffers required--one on either side--to replace the one's I damaged. And also, luckily, I ran across Steve G's neat technique for altering the buffers for installation. If you haven't done this, you will find that one of the two 7/16" bolts can be readily removed, but the second is basically captive unless you want to dismantle a the top A arm/shock. Steve suggests cutting out a segment of the hole on the captive bolt side, making it possible to slide that side onto the bolt without its removal. When the two bolts are snugged down, the buffer should stay in place. Another issue here is cutting away the buffer's sheet metal base plate at the captive bolt so the old one can be removed. I used a sharp chisel for that job. Once again Steve has anticipated what I didn't know. Also, Luke Skywalker says he uses a floor jack under the differential to lift the rear before installing jack stands, and I know I have seen it done, but is that a good idea? All of this tells us that working on Healeys can be challenging, and thank heaven for this Web site.
simon1966 Correct Jack for a 54 100? Austin Healey 5
H correct BJ8 jack Austin Healey 1
Dave Richards Correct Jack for BJ8? Austin Healey 41
M period correct jack Triumph 16
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
K Correct side screen nut for early 58 BN4 Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
I Correct orientation of the fan blades. Austin Healey 13
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 0
K Correct key head shape. Austin Healey 1
Gliderman8 TR6 Correct LED flasher relay Triumph 6
K TR2/3/3A Correct oil level for differential? Triumph 5
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
L GT6 correct finish Triumph 5
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
B MGA Correct wheel paint? MG 2
Gerald_Gordon TR4/4A Inconspicuous or period-correct backup light for TR4 Triumph 8
C Need to order correct size Austin Healey 4
Joe Schlosser correct Dash board color Austin Healey 6
R TR2/3/3A Correct Thermostat? Triumph 7
simon1966 Correct horns for a 54 100 Austin Healey 5
B TR6 Title with correct VIN Triumph 8
BN6_2197 Question on correct oil temperature Austin Healey 15
G Correct spark plug ends - early BJ7 Austin Healey 1
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
S T-Series which way is correct MG 6
K TR2/3/3A Correct position for flasher bracket? Triumph 7
T GT6 These sills have been replaced, correct? Triumph 7
R Correct Brake Caliper colour Austin Healey 9
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
C Correct mounting of exhaust on my 100-6? Austin Healey 9
Got_All_4 TR2/3/3A Throttle shaft assemble does this look correct Triumph 5
Rut TR4/4A Correct grill? Triumph 6
F MGB Correct steering wheel - 1974 MG 2
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
R Cam gear nut correct torque Austin Healey 2
Jake Correct generator pulley and fan? Pics needed Austin Healey 5
T General TR Correct Engine Identification Triumph 2
J TR2/3/3A Correct trafficator control head? Triumph 4
N Correct Bulb Holder for BT7 fuel gauge ? Austin Healey 4
