Luke_Healey
I just got my first Sprite Thursday of last week. It had been sitting in a garage for 20 years. We got it running by Sunday, and driving by Monday.
However, there's an apparent major electrical outage. There are only two fuses on the car though, so I figured I'd ask if there is any obvious things to check out to look for breaks in continuity (or shorts.)
The top fuse seems to be powered up at all times. I can read 12vdc if I apply one lead of the DVM to the fuse and the other to ground.
The bottom fuse gets no voltage, key on or key off. This fuse must control the tachometer, lighting, etc..??? Because none of that works. one tail lamp turns on with the dash switch, but I have no brake lights, horn, turn signals, ignition light on the dash, etc...
However, I can turn the key to the on position and the coil powers up (as does the auxillary fuel pump, but we have it tapped into the coil power.) So the key switch does function at least in some manner.
The fuse with the fat white main wire that branches off to three green wires seems to have no juice flowing through it.
So thanks anybody that can get me started on a fault finding mission /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
