As I've been going through Baby Blue from top to bottom, I know at some point the engine is going to have to be rebuilt. I'm hoping I can get another two driving seasons after this one before I finally bite the bullet, but that may depend on where I stand on my oil consumption and compression. Right now, the oil consumption is around 250 - 300 per quart, sometimes as much as 200 miles per quart, and the compression is showing borderline moderate loss on the leakdown tests last winter. The car still runs fairly strong and the motor runs smoothly despite these ominous warning signs. I think I'm losing more from a leaking pan gasket and main seal than what is burning out the tailpipe, but I'm definitely burning oil.
My original thought was that when I did a rebuild, I'd really go through the car top to bottom. While the car was off the road, I'd pick up something, such as a Miata, or perhaps another LBC to drive while this car underwent a full on restoration. The more I get to know this car, the more I think this car will always be a driver's car and not a concourse car and a full restoration is probably not the wisest choice for it, at least at this point in time.
I then realized that if I was going to spend money on a temporary car, I'd probably be better off purchasing a replacement engine / transmission combination, do the engine / tranny swap and then rebuild the original motor at my own leisure (Or use it the mother of all paperweights). The car would be off the road for far less time. If I go this route, where do you think I would have to be budget-wise? I don't need to worry about labor for the install, just getting another 1275/ribcase combo. I figure I might as well start putting away my shekels now. I don't need to do anything fancy. A stock 1275 would work just fine, although I wouldn't rule out one with a mild build either.
I already have a second ribcase tranny out of a '67 Sprite. It does need a rebuild. Technically, I could get this tranny rebuilt and then pickled while I await a 1275 transplant, which could save me a couple of bucks.
