jvandyke
I've been playing with my HS2s (car as a Weber on it now).
During the winter I went through them, had both pistons moving well, jets centered, decently matched, one would sometimes stick when I pushed the piston all the way up. Took it apart to play. I put fluid in the dashpots for the first time, ATF as I read that was good to use.
I was very surprised how much resistance there was when replacing the damper rod/cap into the dashpot.
I was more surprised when I then lifted the piston with my finger, wow that's a lot of resistance. Pistons both fall back to the bottom but a lot slower. If I raise the piston all the way; now the OTHER piston doesn't want to fall back down. If I take out the damper rod it drops like a stone.
Is this normal? Does the piston not ever get all the way up under normal operation and therefore I don't need to worry about that "bench test"?
And: I put a tiny tool mark on a needle trying to extract it, is that wrecked now?
I need new springs, one hook broke off of one, other looks near to the same fate. Anyone have some spares?
