Needing Ideas and information... Duh!
Jim Weatherford
If and when I get the crankcase pressurization (blow by) problem solved and I'm no longer pumping oil directly into the exhaust system, How do you get the oil out of the existing exhaust system, short of taking it off of the car?
I was thinking of drilling a hole or two in the lowest part of the exhaust pipe and the pre muffler and let the exhaust pressure purge the pipes and muffler then weld it up when I'm sure I have it as clean as it's going to get. This is the best my feeble mind could come up with. Any really good ideas are welcomed.
After I'm sure I have the problem taken care of... I have a new stainless headers & exhaust system from Bassani that I'm planning to install. I just want to get back on the road w/o smoking and looking like I'm on fire!
A little more detail of what happened...
I wasn't having any oil problems at all & #13046 was running fine. I hit that piece of angel iron on the freeway and damaged the rear transmission mount, a control rod and other suspension parts were damaged. I took the vehicle to British Sports & Imports in Riverside and had repairs made. I had previously removed the air-box which wasn't connected or working, and installed the K&N filters on the Stroms. When I did that I didn't know to connect them to the crankcase vent. I was told that several vacuume hoses were also replaced as needed, seems they were cracked and split, unfortunately I don't know which hoses were replaced.
I took the car out to track day and cleared tech and ran a few laps and I then started to smoke badly, I shut her down and took the car a week later to Britallia in Anaheim and he checked the compression [148 psi avj.], a leak down test and checked the guides. He couldn't find anything that out of spec. Next he removed a spark plug and stuck a bore-scope in all 4 cylinders and each one had oil floating on the tops of each piston! I think he said "a-wash in oil". He suggested venting the K&N's as a possiable fix.
I've ordered the parts to do the venting and if this fixes to over presserization problem I will be very happy, but I'm stuck on how to get the oil out of the exhause system.
I hope this helps by adding a timeline of events and repairs. Sure would be nice to get this behind me.
Thanks. /ubbthreads/images/graemlins/patriot.gif
piman
Hello Jim,
I personally would not worry about oil in the exhaust system, just run the car, hard if possible, and let the hot exhaust gasses clear it for you.
Alec
waltesefalcon
Jim,
I'm with Alec. Don't sweat it, like he said run it hard and let the exhaust gases blow it out.
Keoke
Jim, does the car contain a PC valve in the crankcase ventilation system>???---Keoke
J
Jim Weatherford
Thanks all, I hope I can drive the oil out, by driving without getting a citation from the So. California Air Quality Management District (SCAQMD) I look like a ship laying down a smoke screen.
Keoke;
No, no PCV - The crankcase ventilation system on the Lotus 907 is pretty marginal at best. I am in the process of venting the crankcase to a catch can and venting the vacuume back to the carbs. The air box wasn't connected when I removed it and installed the K&N air filters, so I didn't connect the vent line then, so... I don't know if this will help, but it won't hurt either from what I've been told. I am also checking all venting hoses and vacuume lines, considering I had a small amount of oil in the brake booster which is vacuume assisted.
Any and all ideas are welcomed and considered. Many thanks.
Keoke
OK Jim, is the smoke white or blue.????--Keoke
J
Jim Weatherford
Keoke;
The smoke is whiteish with a blue cast! We checked for water in the oil when we sent the sample to the lab and it came back clean. The odor is also very, very faint, which is atypical of just burning oil, but it has been hard to pin down. There is no smoke until the car heats up, then it is a fair amount and under excelleration is almost goes away, when at idle in billows out of the tail pipe only.
Keoke
OK Jim, You mentioned that there was some oil in the brake booster,so try disconnecting the vac line fom the engine to the booster and plug the engine side of the vac line closed, now give it a run and see if the smoke goes away.--Keoke /ubbthreads/images/graemlins/smile.gif
J
Jim Weatherford
I'll give it a try, but there is still considerable oil in the pipes and muffler. It may be hard to tell if there is a difference right away. My JH is parked in my shop and I'll get over there Saturday and see whats up. I also picked up the AeroQuip connectors, braded steel hose to hook up the K&N to the catch can, I may get to that also. Boy! It was almost $280.00 in connectors and hoses. I've got to go to the surplus stores next time. I'm also looking for a 12" to 18" bore-scope, I saw one at the overstock & military surplus store in Pasadena back a few months for $45.00 I should have picked it up then, oh well.
Keoke
OK
Well after a good run you can see if the oil is no longer on the piston tops.---Keoke
Bugeye58
Jim, you flat got ripped off on the hose and fittings. For less than $280.00, I plumbed my entire oil system, from the block, to the filter, through the cooler, to and from the accumulator. All in #10 AN hose.
Jeff
Keoke
Yes that was a bit pricey-Huh---Keoke /ubbthreads/images/graemlins/frown.gif
J
Jim Weatherford
Needless to say, now that I know what I'm purchasing and how to order... JEGs, Summit, etc., here I come, and I will not be going back to them again. "Once Burned, Second Time... Wise." Thanks.
J
Jim Weatherford
Guys;
What is a good sourse for AN connectors and braded steel hose, my next project is the oil cooling system and I don't want to get taken again. Thanks.
D new member needing help with buying a 3000. Austin Healey 39
B TR2/3/3A Is a 63 TCF probably needing total restoration worth getting into? Triumph 16
T needing some valve seat guidance here Triumph 6
donbmw Tach needing repair Triumph 8
P BJ7 Restoration needing help Austin Healey 4
Adam58 A couple of English Fords needing adoptive homes Other British Cars 1
1 Fuel pump needing a tap -- approaching doom? MG 4
J New member needing windshield replacing tricks Spridgets 3
P New member needing help with 63 BJ7 Austin Healey 7
T Doors sag a little, needing a little lift to close Austin Healey 2
G NuB Needing Firing Help! Sunbeam (Rootes) 7
B Cove Paint Color Ideas Austin Healey 10
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
L Tyre diameter less than 680mm but bigger than 640mm, any ideas? Austin Healey 11
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
pbraun Ideas on tires for Bugeye with 13x6" wheels Spridgets 3
nathandarby67 Ideas for organizing hardware when plating Restoration & Tools 6
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
Sarastro General Tech Any good ideas for removing liners? Triumph 20
Sarastro TR4/4A Any ideas for repairing jack damage? Triumph 13
Jim_Gruber Need your ideas on a How To Do it - SpeedHut Gauge Install Spridgets 11
Rut TR4/4A Shop with lift ideas Triumph 21
maxwedge5281 third brake light ideas Austin Healey 34
B TR6 Seat Belt Brackets - Any Better Ideas? Triumph 1
M TR4/4A Covers at side of H frame over the trans tunnel...ideas please. Triumph 9
M General Tech Creative ideas, shop equipment, fabbing techniqes, etc Triumph 0
chuckmcb Baffled by BJ8 Ignition light...any ideas? Austin Healey 9
MikeAH100M Ideas for an Alloy Racer Austin Healey 13
trotti Stuck drum - any ideas? Austin Healey 5
CJD TR2/3/3A Engine Storage Ideas Triumph 2
T TR4/4A Lowering my TR4a - ideas? Triumph 18
catfood Any Ideas? Austin Healey 7
aeronca65t Christmas Card ideas Other British Cars 5
RickB Any temporary Bugeye grille ideas while I send mine off? Spridgets 16
bthompson Using the brakes kills the engine! Any ideas why? Spridgets 17
I Bugeye bonnet hinge bolt head busted off - ideas? Spridgets 8
RJS Top Frame Repair - ideas needed Triumph 8
Mychael Ideas for a parcel shelf in a Frogeye Spridgets 8
T ideas on fixing - one carb keeps "rusting" Triumph 4
I TR6 TR6 difficult to start - ideas? Triumph 6
M Any Ideas Triumph 26
K Any ideas for a Handbrake Warning Light??? Triumph 11
bighealeysource ideas on how to fix dents on frame Austin Healey 15
Darrell_Walker Alternator cleaning ideas Triumph 10
ahealey1004 bn4 drum brake issues...any ideas? Austin Healey 7
apbos TR2/3/3A Ideas for moving my TR3a????? Triumph 4
M 948 vs 1275 - Looking for opinions and ideas Spridgets 34
Brosky Upholstery makers in England? Any ideas? Triumph 21
T Ideas on fixing this? Triumph 19
eschneider leakdown test readings - ideas? Restoration & Tools 12
