ideas on how to fix dents on frame
bighealeysource
Hey y'all,
Okay, any ideas on how to best repair the multitude of small dents on the horizontal surface on my 100M's frame rails ?
Primarily in the middle of the frame close to the crucifix area. Vertical sides are fine, just the bottom. Have no idea how they got there in one general area but this car was raced extensively in the late 50's and early 60's. None are huge, really just cosmetic but other than getting a new frame - which I am not interested in doing- thought there might be some suggestions on how to repair. I know, why bother but if I can fix the worst of them would be nice to clean them up.
Thanks,
Mike
TimK
Sounds like jacking dents? One idea, maybe not a good one, would be to drill and tap holes and use a slide hammer attached to a bolt in the tapped holes to hammer out the dents. Then you could weld the holes shut. Another idea, would be to use body filler.
elrey
You must be careful or you can rip the seams [center ribs] apart, as the frame rails are made up of two C shaped channels welded together at the ribs.
pkmh
Many years ago, when I was one of those "artichokes" in life (architects to you), I do recall learning how steel's strength design is always best in tension, more so than in compression like concrete (concrete by contrast, is poor in tension--that's why you see re-bars in concrete, to make up the tensile strength missing in concrete). The subject of dynamics like bridge design is another subject so "I'm out".
Back to classroom 101 statics, and I have to look at the Healey frame as one of static design even though I bet it could fall under dynamics as well because the car is in motion, too. I'll leave that up to the engineers to argue.
But if it were me, rule number one: Never compromise steel's strongest area of design which in this case, would be the bottom flange which acts in resisting moment forces (twisting, buckling). The webs of the box beam resist shear forces. How bad are these dents? If it's a cosmetic issue, I wouldn't drill any holes. I would bondo it and live with it.
If these dents are nasty and forcing the webs to actually become deformed, one approach I would use is to drill a small hole on the top flange, place a steel plate firmly at the underside of the bottom flange in need, and hammer a durablee steel dowel through the opening to the affected area. Kind of acting like a jeweler do fancy chaise work.
Rule number two. ALWAYS drill along the neutral axis of any web or flange. That is, the center of any web height. Example, if you have a 4" high web, then you drill at the center which will be at the 2" diameter on center mark. These areas yield the least amount of stress (you'll sometimes see drilled holes on wooden beams for the snaking through of electrical BX wires). If not, sue your electrical contractor, immediately!
Paul
PS - BTW, I will define the web of any steel beam as the vertical section which connects one or two flanges which are horizontal (basic box beam has two flanges, and of course, two webs, usually). So whereever the two webs are along the flange, then drill center (neutral axis) and inbetween the two webs. If the box beam is a composite design (IE. two box beam sandwiched together). them the same rule applies--always inbetween two webs or not center of the composite design.
Any engineers out there want to argue? I am just a former artichoke. I am all ears here!
John Turney
richberman said:
How about one of these?
https://www.eastwood.com/stud-welder-dent-pulling-system.html
Same idea as TimK but no holes at the end to fill.
rich
The Healey frame metal is thick er than typical body panels. I'm not sure that the weld-on pins would be strong enough to pull the frame dents out.
I will agree with pkmh that drilling holes in the bottom will weaken the frame (and I'm an engineer). I don't like the idea of drilling holes in the top, though. There's just too much stuff in the way.
I also don't know how well filler would last.
I'm with Rick.
HEALEYJAG
Lead them in??????Not sure if this is still available??
Pete
Brinkerhoff
You are correct, the type of puller used to pull fender dents with weld pins will not produce enough force to pull the steel frame rail. I 've taken a 3/8" threaded rod about 36" long and welded it to the seam of the rail on both sides with the mig welder. Then taken the bell from my axle slide hammer ( about 10 lb.) and slid it on to the threaded rod , then put a large flat washer and a nut on to the rod. With the weld still hot , pull smartly like you were pulling a hub off an axle. Your weld needs to penetrate both the seam and the rod. If you are good at welding, the threaded rod will pull off the frame after one or two pulls ( without damaging the seam) as it pulls the dent out. If you over pull it , whack it back with a big hammer and a block of wood. If the damage flares into the side of the rail , as you slide with one hand , hammer in with a flat body hammer. Metal finish as you are capable of. A little finishing plastic will stick just like on a fender. Dress the weld off the rod with your Makita grinder to prep it for the next area. Time consuming, buy hey , in for a penney in for a pound ! I fixed quite a few areas on my BT7 chassis and they are still undetectable after 10 yrs. the chassis is painted with a basecoat /clear. Kevin
Keoke
rich
Well they will work just fine if you heat the surrounding metal before you try to pull it out.
Naa it will be ok after you fill the hole and lead it over
Nope it will eventually fail
I'm with Rick.
Barryp
Mike,
My frame had quite a few of these as well. I did a fix similar to what Kevin mentioned. I used 1/2" all thread, cut a slot in the end so it would fit over the frame seam if that's where the dent was and then tacked it in place. Dilled a 1/2 hole in a 6" or so 2x4, cut relief slot across the 2x4 hole to give the seam a place to go. Then tightened a nut down on top of the 2x4. Worked really well
Barry
bighealeysource
bighealeysource
Hey guys,
Thanks for the advice and suggestions. Think I'm going to take Rick's advice and leave well enough alone ! I could just see me making a minor problem into a major problem. This frame had enough abuse when the car was raced don't need any more from me !
Thanks again,
Mike
me61ic
bighealeysource said:
Hey guys,
Thanks again,
Mike
A bit late to respond to this relatively old thread, but this is what I planned on doing in my car that has the same problem, probably due to the use of car jacks.
It is taken from John Loftus' page on his restoration of a BJ7:
https://www.loftusdesign.net/restorationweb/dentpulling1.html
https://www.loftusdesign.net/restorationweb/dentpulling2.html
BigGreen
+1
Before you start pulling and wacking inspect the inside
I would not stretch the steel another time
If you hate the dents fill them up
Not with bodyfiller, not with lead, but with serveral welds
A thicker frame wont hurt ;-))
Afterwards do protect the inside against rust
Hans
Brinkerhoff
No, the seam is the strongest part . Welding the slide hammer bar to it will soften the surrounding metal slightly allowing you to pull the metal out.
L Tyre diameter less than 680mm but bigger than 640mm, any ideas? Austin Healey 11
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
pbraun Ideas on tires for Bugeye with 13x6" wheels Spridgets 3
nathandarby67 Ideas for organizing hardware when plating Restoration & Tools 6
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
Sarastro General Tech Any good ideas for removing liners? Triumph 20
Sarastro TR4/4A Any ideas for repairing jack damage? Triumph 13
Jim_Gruber Need your ideas on a How To Do it - SpeedHut Gauge Install Spridgets 11
Rut TR4/4A Shop with lift ideas Triumph 21
maxwedge5281 third brake light ideas Austin Healey 34
B TR6 Seat Belt Brackets - Any Better Ideas? Triumph 1
M TR4/4A Covers at side of H frame over the trans tunnel...ideas please. Triumph 9
M General Tech Creative ideas, shop equipment, fabbing techniqes, etc Triumph 0
chuckmcb Baffled by BJ8 Ignition light...any ideas? Austin Healey 9
M Ideas for an Alloy Racer Austin Healey 13
trotti Stuck drum - any ideas? Austin Healey 5
CJD TR2/3/3A Engine Storage Ideas Triumph 2
T TR4/4A Lowering my TR4a - ideas? Triumph 18
catfood Any Ideas? Austin Healey 7
aeronca65t Christmas Card ideas Other British Cars 5
RickB Any temporary Bugeye grille ideas while I send mine off? Spridgets 16
bthompson Using the brakes kills the engine! Any ideas why? Spridgets 17
I Bugeye bonnet hinge bolt head busted off - ideas? Spridgets 8
RJS Top Frame Repair - ideas needed Triumph 8
Mychael Ideas for a parcel shelf in a Frogeye Spridgets 8
T ideas on fixing - one carb keeps "rusting" Triumph 4
I TR6 TR6 difficult to start - ideas? Triumph 6
M Any Ideas Triumph 26
K Any ideas for a Handbrake Warning Light??? Triumph 11
Darrell_Walker Alternator cleaning ideas Triumph 10
ahealey1004 bn4 drum brake issues...any ideas? Austin Healey 7
apbos TR2/3/3A Ideas for moving my TR3a????? Triumph 4
M 948 vs 1275 - Looking for opinions and ideas Spridgets 34
Brosky Upholstery makers in England? Any ideas? Triumph 21
T Ideas on fixing this? Triumph 19
eschneider leakdown test readings - ideas? Restoration & Tools 12
D help...? Air Filter ideas needed...nothing fits! Spridgets 23
A TR4/4A TR4 mistery engine problem - any ideas Triumph 14
startech47 Any ideas? Spridgets 8
gubba Slight front end shimmy @ 52 mph any ideas? Triumph 13
T Ideas on getting this bolt unstuck Triumph 42
RickB New steering wheel, ideas about adapting? Spridgets 23
bighealeysource Ideas on where to get ID plates stamped Austin Healey 3
M Need Engine Swap Ideas for '76 Midget Spridgets 21
T TR2/3/3A TR3A vibration - looking for ideas Triumph 38
RickB Ideas about modifying seats to fit rollbar? Spridgets 6
R front emblem rehab ideas??? Triumph 16
scubabatdan Ideas on cleaning a yellowed rear window? Spridgets 1
bmurphy7369 Let's Help Basil with Recent Cost Issues, Ideas... Austin Healey 0
bmurphy7369 Let's Help Basil with Recent Cost Issues, Ideas... Spridgets 0
