Im not so sure. There is a big difference between a hub puller and a brake drum puller. Hub pullers are used to pull the rear bearing hub assembly off the rear axle. Brake drum "pullers" are usually not pullers, but more looseners. I have seen massive cast iron 12" brake drum type pullers, but I have a cheap "loosener." Hub bearing pullers are around 5 tons ( capacity not weight), i have a 2/3 jaw craftsman that worked on the bugeyes replacement bearings. -Josh
[ 02-03-2003: Message edited by: jha2297255 ]</p>
