Front hub puller?
drooartz
What sort of hub puller do I need for the front hubs? I'm in the process of disassembling my disc fronts, and need to get them apart so I can send the A-frames/kingpins out for rebuilding.
PeterC
Drew, No hub puller needed. If you have wire wheel hubs there is a grease cap that can stump you briefly, but otherwise, undo the split pin, undo the nut, and pull. It will come off disturbingly easy.
Peter C.
drooartz
drooartz
These are disc wheels. So I can just pull the hub off the stub axle? Geesh...
sparkydave
Not much force at all. One of mine needed very little persuasion with a 3 armed puller, the other one came right off.
drooartz
drooartz
I'll give it a go tonight. I'll admit, I never even tried to pull them off, figured the tool was necessary.
Well, that's what the manual said! /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
B_Hiles
Peter C.
Don't forget about the tabbed washer behind the nut. If you don't remove that first, it can make things a little more difficult.
drooartz
drooartz
Sure enough, couple good pulls and everything came off. Just need to get the bearings out, and all will be well. A-frames and kingpin are ready to be sent out for work now.
jlaird
Drew, you rolling right along.
BillD Front hub puller Spridgets 21
Lon_S What hub puller tool works well for the front hub? Spridgets 2
Carlbanan56 MGB Front hub MG 4
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
A BN7 Front Hub Stud Nuts Austin Healey 5
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
K TR2/3/3A Front Hub and Felt Seal Triumph 1
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
MikeAH100M 100 Front Hub Spacer/Distance Piece Austin Healey 2
warwick-steve Missing grease cap in front hub Austin Healey 8
warwick-steve Front hub bearing grease repacking Austin Healey 28
K TR2/3/3A Front hub oil seal Felt? Triumph 1
K TR2/3/3A Front wheel hub "felt" again? Triumph 2
K TR2/3/3A Front hub wheel bearing nut? Triumph 1
aero3113 Front Hub Inner Bearing Seal Austin Healey 7
pkmh "Bearing Outer Race" Re-installation at Passenger Front Hub Extension Austin Healey 4
Jeepster Front hub replacement. Austin Healey 34
R TR2/3/3A front hub seal options Triumph 9
Bob_Spidell Securing Front Hub Bolts Austin Healey 8
T TR4/4A Front hub grease cap sizing - anyone had a cross reference part # for a FLAPS? Triumph 2
C Front Hub Castle Nut Austin Healey 8
B TR2/3/3A TR3 Front Hub Felt Seal questions Triumph 2
M_Pied_Lourd TR2/3/3A 59 TR3A Front Hub Oil Seal Triumph 2
R BJ7 front hub shim question Austin Healey 18
catfood Removing front hub Austin Healey 6
RAC68 Calculating Front Hub End-Play Austin Healey 32
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
Jim_Gruber Removing front wheel bearings from hub Spridgets 6
bertl Front Hub Spacer Kit Triumph 1
Scotsman TR2/3/3A tr3 front wheel hub stud removal Triumph 2
H front hub removal Austin Healey 37
6 front hub options... Triumph 4
S Spitfire Question on front Hub for a triumph Spitfire. Triumph 4
pkmh Dismantling BJ8 Front Hub From Caliper Disc Austin Healey 20
Willie_P TR 3/4 Front Hub Install - question Triumph 15
J Front hub mystery Austin Healey 0
britndablood To install or not to install Front hub spacer Austin Healey 8
TR4nut Front Hub Felt Seal - Old vs New Triumph 15
D Need a front hub Austin Healey 1
S Front Hub Replacement Austin Healey 7
G Front hub Spridgets 2
TonyPanchot tork settings for 1997 front hub Jaguar 1
TR3driver Front hub balance problem Triumph 17
M Front hub worn out Spridgets 6
Monark192 MGB-GT 67 GT front hub removal MG 10
drooartz Front hub/brake question Spridgets 12
Jim_Gruber Castle Nut on Front Wheel Hub Spridgets 6
B TR2/3/3A TR3 front bearing/hub advice needed Triumph 6
19_again front hub removal MG 3
