TR6 Help installing the Gear Box 1972 Triumph TR6
spicybbq
Hi Everyone. I have done this job on multiple spitfires and even a TR4 by myself. Here is whats going on. I pulled the gearbox from my TR6 and replaced the clutch/had flywheel remachined/new pressure plate, etc. Clutch alignment tool worked well. Now I am having a horrible time getting the gearbox to mount to the motor. I pulled the gearbox from the inside of the car. Should I pull the driveshaft? It is just so awkward and difficult to handle. I may have to enlist some friends but I would rather do it myself. I know TRF has some pins that go on the sides of the bellhousing to help align things. PLEASE HELP!!!
alanjohnturner
I have a wooden trolley made like this. It slides under the car and then you fit two adjustable jack-screws.
You can set the gearbox height exactly and then just run it up and mate the input shaft.
You can concentrate on rotating the spines so they slip in.
Break off, have a beer, and come back and the gearbox is waiting there for you.
TR3driver
Great Pumpkin - R.I.P
Uhm, if you cannot get the gearbox mated, how do you know the alignment tool worked well? I've not tried the TR6 tool, but the TR2-4 tool I got from Moss was nearly useless. After several hours of trying to get things mated, I pulled the gearbox back out and felt down the hole with my fingers, to discover that the plate was significantly off-center to the crank. When I recentered just by feel, it all slid together easily.
Now I always use an old input shaft. The fit is obviously much more precise than the tool, as the tool would wobble around even with the pressure plate bolts tight, while the input shaft will only move by a few .001".
Geo Hahn
Similar to Alan's trolley, I have used a HF Transmission Jack.
I have also had occasion to slip a metal rod (an old jack handle) under the tailshaft so it is supported yet can be rolled for & aft.
Finally, I made some headless bolts to temporarily screw into the engine side to guide the bellhousing home:
All these were on a 4-cyl gearbox -- not all were used each time, just a matter of what seemed right for the job at hand.
mrv8q
So, a couple questions about spicybbq's situation. Generally, do you raise the car on jackstands high enough to clear rolling the now-unmated gearbox on a trolley under the car and out? Or do you leave the car on it's tires, drop the gearbox on a trolley, and then horse it out thru the interior?
How do you support the engine whilst the gearbox is out? 2X4 across both fenders, and a chain from the rear engine hoist bracket to the 2X4?
Thanks for the opportunity for letting me use whilst....
DNK
You are using the recommended bolt method as per the manual...correct???
titanic
If you haven't done so, join the Portland Triumph Owners Association, many members would be glad to help or advise. I have found that the secret to getting the trans. to mate with the engine is keep the gap even all the way around as the trans is moved forward. The dowels also help to support the trans and prevent damage to the clutch disc and imput shaft. As mentioned, a trolley jack is helpful to adjust the heighth and forward movement. Raising the engine as high as possible may also help. R&R the trans. is about a 4 Chiropractor visit job, depending on age, strength, and if an OD is attached. Berry
S
spicybbq
I have the front and rear of the car on jackstands. I am not supporting the engine but I do have a cherry picker I could use to support it. I know the alignment tool worked because it fully inserts and the end piece fits into the bushing in the flywheel. I confirmed this. I like Alan's diagram. I may try to build one of those units.
poolboy
Did you jack up the engine enough to make it level again after having removed the gearbox ?
Do that; have the 2 alignment dowels on the engine plate inplace and a hand on the tranny's mainshft flange to align the mainshaft spilines with the clutch and some grunting. ..that and a 3rd hand really helps .
glemon
OK, this is not the finesse precise intellectual response, but the garage ape approach, but has worked well for me when I have put trannys in by myself, usually pretty easy to get the first part started, but then many times hangs up, but get it started and aligned as well as possible. At this point put a thick towel or some padding on the emergency brake, sit down on the e-brake, put your feet on the flanges on each side of the bell housing of the tranny, and your hands on the end of the tailshaft, from this position you can alter the angle of the tranny slightly and also turn the splines by turning the flange on the end of the tranny. Of course you don't want to get to crazy, but with a little up and down and side to side with some forward pressure from the legs, and you can usually find the sweet spot and slide it the rest of the way in.
mallard
Make sure the fork pins are still in the groove on the throw-out bearing sleeve. You can put a piece of wire around the fork pulling it back so the bearing sleeve does not slide forward and disengage the pins. Make sure you are able to pull the wire back out before bolting things up. If this happens you will not be able to close the 1.5" gap between the engine and the bell housing, which is a good thing. As mentioned above make sure you jack up the engine so it sits level with the trans.
Gliderman8
I used a small bottle jack under the engine to help align the shaft in addition to the alignment dowels. It is a job, there is no doubt about it, but you will get it.
RomanH
To add to all of the sound advice above another little trick that helps, along with having the rear of the engine supported, is it may help to put the trans in gear and rotate the output flange to try and get the input shaft splines to align with the splines on the clutch. All while applying forward pressure on the trans.
55modified Help installing toggle dip switch on dash for lights. Austin Healey 23
V General TR Need help with installing glass and new seal into my surrey top. Triumph 2
RickPA Need help installing steering idler oil seal Austin Healey 6
S Installing Power Brakes in BN4, need pics to help locate the Servo Unit installation Austin Healey 10
2wrench TR6 Help installing door handles/window regulator handles. Triumph 9
I Help on installing side curtains and rag top on Bugeye please Spridgets 4
A Serious help needed !!!! BJ7 Installing a new soft top Austin Healey 9
I TR6 Help installing TR6 door pulls and fuzzy seals Triumph 14
Johnny Help installing a transmission. Austin Healey 13
S Installing 3 pc. cockpit chrome. [b]I need help[/. Triumph 5
bighealeysource Help with installing new top on 100-4 BN1 Austin Healey 4
bighealeysource Help on installing carpet on BN1 Austin Healey 4
S Help! Installing Rubber on Header rail MG 5
DerekJ Installing Sport Coil - Help Please Austin Healey 28
C TR2/3/3A So many newbie questions any help is appreciated! Triumph 4
J Wanted Help Wanted -SE WI Other British Classifieds 0
J Help Wanted - SE WI Racing 0
Darwin Spitfire Motor mounting help Triumph 1
Dnickels Spitfire Speedo help Triumph 4
RGK TR5/TR250 SU carb ID help Triumph 6
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
AngliaGT Help Me Identify These Parts Jaguar 6
jlaird MGB V6 carb help MG 14
nichola TR6 Help me - circuit breaker above horn relay Triumph 5
T Bug Eye Heater Switch Help Spridgets 2
G General Tech Help TR-6 Triumph 24
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
S Axle Shaft Installation Difficulty - Help Sought Spridgets 8
R Rust in Block? Help needed! Austin Healey 6
D PDF attachment help FORUM Help 1
M General MG OEM Radio wiring help MG 4
J MGB Need help identifying these parts MG 6
G 1960 3000 BN7 Top Help Austin Healey 0
P Carb Help - Car idle slows and dies after being run for a while Austin Healey 14
B MGB-GT Need help with MGB GT rattle MG 0
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
JPSmit Plywood - woodn't you like to help Restoration & Tools 8
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
Bayless Login problem need help FORUM Help 7
B TR4/4A Help indentifying these Triumph 5
N Please help --- New owner of a 1958 Austin Healey Sprite Spridgets 4
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
6 Master Cylinder Rebuild Help Please Spridgets 3
D photobucket image help FORUM Help 2
TRclassic3 TR4/4A Help with deciphering front suspension problem Triumph 11
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
P A little identification help please Other British Cars 10
