AUSMHLY
Hi guys,
If any of you are following the missery I am going through with my body shop, please, please work on my car, saga, he just asked me if I can get a new front shroud. Yikes, I just found out how much they are. Soooo, just by chance, I took a look see on ebay. And what do you know, someone is selling one.
I have a 64 BJ8 phase II. The one on ebay is from a 62 BT7. Are they the same? I think the turn signal diameter is different, maybe fixable. Any other areas? What's your thought on the condition of this one? Here's the link.
https://cgi.ebay.com/ebaymotors/Austin-He...568880741QQrdZ1
The body shop bead blasted my car, so my front shroud shows all the poor previous body work done, and lots more needs to be done to correct the privious guys. Heard this story before?
He can repair mine, but it will require a lot of work aroung the grill, hood lip and left headlight area. Plus he will need to add the no no, bondo. Which he says he doesn't want to do, but will end up doing if I keep mine.
Looking forward to your thoughts.
Thank you, Roger
Thank you, Roger
