Marvin Gruber
Does anyone have a old 3000 front shroud they are cutting patches from? The BJ8 shroud I have has a piece on the lower right size the was torn off at the frame mount area,
Marv
Marv
Wow, lots of good stuff there! My shroud is good, just need piece/strip of aluminum at the bottom to weld in. Thought someone here would have damaged shroud I could get a piece from.
Marv
How are you going to attach the replacement piece? Glue or aluminum .weld?
I have a friend who is an excellent aluminum welder. O/A torch can be done but you do have to know what you are doing.
Marv
MIG with a spool gun is easier than TIG, at least for me. Of course, one needs to use aluminum wire in the spool gun and pure argon gas instead of the CO2/Argon mix used for steel.
