Glen_B
I had a very productive weekend of tuning on the EFI system. The "Autotune" function works great. I can catch the laptop screen out of the corner of my eye while I'm driving and watch it working away like a demon perfecting the fueling table. After a 50 mile drive with little bursts of "boost" and some steep uphill, much of the table is now populated with "corrected" values and the car runs great. The plugs look PERFECT after the drive and the gas guage didn't even move off "F". There is absolutely no overrun when you shut this system off. I can't wait to see what kind of mileage I'm getting now, but I'm absolutely sure I'm getting better mileage based on the plug cut. I don't ever recall having the motor respond so well across all gears and RPM as it does now. No lean spots, no rich spots, great acceleration without a hiccoup.
This week's agenda is to erase the original code on the CPU and load in the expanded code that will allow me to hook up the ignition to the computer as well. I will be able to put in any custom advance curve, start-up timing adjustment, and manifold pressure indexed boost retard. The expanded code gives me a 16x16 table for fuel values and for spark timing. Sweet! I built all the necessary bits into the computer for spark control at the start, now its time to take the next step.
Glen Byrns
Glen Byrns
