Evante EFI Conversion
G
Update on converting my Evante to EFI and EDI -
I've made a few posts regarding my EFI conversion previously. As anticipated, it's taking twice as long as I thought it would. But hey - it's only costing about 1.5 times as much as I originally thought so I'm about 25% under budget!
Pics are here: https://www.obrox.com/EFIConv/
The throttle bodies are in. This was easy - just bolt on. But it took me 2 sets of injectors to get that part right. The first set didn't quite fit correctly. (And I'm too embarrassed to tell you how many cables I cut short when I was constructing my wiring loom for the injectors.)
It took a while to find someone to weld new fittings onto my fuel tank without asking for my first born child. (Which was a real problem for me - I've never had kids and it's too late to start now. You'd think they were worried about getting blown up or something.) But Culpepper Tank and Radiator in Suffolk, VA came through on that part for me. It took me about 5 weeks to get back to work on it after I got the completed fuel tank back. ~ But now I got some junk unda hood and some junk in da trunk too!~
The fuel system is overkill. But I found it difficult to find good supplies and pricing on components designed for less than 200 HP - hince the -6 and -8 hoses, regulator, filter, and pump.
I got my Microsquirt ECU some time ago and after much debate decided it will be mounted underneath the passenger seat. I've also bought a VR sensor, trigger wheel, and dual coil pack for wasted spark EDI but I may decide to trigger and distribute off the distributor for a while at first and put this part off until later.
Anyway - thought some of you would be interested in seeing and hearing about the (slow) progress. Hopefully I'll be able to get the wiring and sensors finished over the next 2 - 3 weeks. Maybe I'll even get it started for the first time before Thanksgiving!
HealeyPassion AH Sebring/Ruddspeed EFI project car Austin Healey 6
HealeyPassion EFI AH testing/tuning remotely Austin Healey 2
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
F TR6 Patton EFI Triumph 1
I TR6 TR6 EFI Conversion Triumph 19
HealeyPassion AH EFI build... again Austin Healey 41
HealeyPassion EFI AH Initial Test Day... Austin Healey 6
Tremelune EFI, engine swaps, reliability... Spridgets 12
RAC68 Wedge TR7 - Anyone Convert from Carbs to EFI Triumph 6
Glen_B EFI Megasquirt help available Spridgets 37
Morris EFI for you Doug Spridgets 5
L Turbocharged, efi MG MIDGET. VROOM, whoosh, psssss Spridgets 19
S Wedge TR8 non EFI, Air Filters Triumph 2
S Wedge 1980 TR8 a/c non efi Triumph 19
HealeyPassion EFI Healey project Latest Austin Healey 14
T Mega-Squirt EFI [for A series engines?] Spridgets 6
HealeyPassion EFI Healey project Latest Austin Healey 3
Bret Bret's EFI Skunk Works hits a few speed bumps. MG 9
Glen_B EFI bugeye HP numbers Spridgets 4
Glen_B Here are some efi pics Spridgets 14
Glen_B EFI is FINISHED!! Spridgets 10
Glen_B Turbo EFI progress Spridgets 14
Glen_B Bugeye EFI progress Spridgets 10
Bret Up-date on Bret's MG Skunk Works EFI project MG 7
Morris Midget EFI: Opinions wanted Spridgets 15
Glen_B EFI progress Spridgets 5
Glen_B Megasquirt EFI on bugeye Spridgets 11
Morris Midget EFI pics Spridgets 8
Morris Midget EFI fuel pressure problem Spridgets 10
M 4CU EFI Module 3.5L Rover V8 1985 Marcos Mantula Rover / Land Rover 9
Bret Bret's EFI & O/D transmission MG 7
Bret Woo Hooo! Up-date on my EFI kit installation! MG 5
Bret Moss EFI kit and O/D tranny Latest thus far... MG 8
healeynut Healey EFI ... q's??? Austin Healey 7
R ALANA -- How's that EFI going? Triumph 14
Atrus Megasquirt EFI Question Spridgets 7
Morris Spridget EFI survey Spridgets 11
LastDeadLast Pinging Alana, EFI related Triumph 1
Morris AH Spares EFI Spridgets 3
A TR6 TR6 EFI - where do I start? Triumph 26
8 efi relay Jaguar 4
Bret Speaking of the Moss EFI kit MG 2
B Spitfire common EFI swaps for 1500 Spits? Triumph 5
Bret Moss EFI kit & other good news! MG 14
Bret MGB Moss Motors EFI for the MGB! MG 3
StagByTriumph Wedge TR7 EFI system on Ebay Triumph 7
Bret MGB MOSS's EFI kit for ZS MGBs MG 2
AndreL TR6 Conversion to electric fuel pump Triumph 10
mctriumph TR2/3/3A Ultimate fan conversion Triumph 10
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
