Difference between 16acr and 18acr alternator
Cookie
Member
Dear all
It's getting cold and so is my little car. Trouble is she doesn't like it when it's dark and her lights heater and windscreen wipers are all on at the same time.
So it's time to sort out my flailing alternator. She's a late 71 Sprite but I don't think she has her original alternator. I'm looking at a replacement and have found a good deal on an 18acr which seems as though it would give a better output.
Can anyone tell me if it should just drop on as a direct replacement for a 16 or 17acr depending on what I already have?
Any advice would be greatly appreciated..
Cheers mateys! xxx
Sarastro
Take a look here. This seems to imply that all these alternators were used on A-series engines at one time or another, so it seems that they should fit. The 18ACR is a bit higher in current, which is worthwhile.
Another option is to go all the way and put in a 55 amp Fiesta alternator; see the Wiki. This will give plenty of power, and isn't expensive.
M TR4/4A Difference between two Oval Air Filters Triumph 3
AUSMHLY The difference between GL4 and GL5 gear oils Austin Healey 0
Got_All_4 TR6 Any difference between 69 & 70 camshafts Triumph 3
K TR4/4A Difference between 4A frames and TR6 frames? Triumph 6
C Price difference between 100-6 BN4 and BN6?? Austin Healey 14
M TR4/4A Is there a difference between the "Body" number and the Comission Number? Triumph 8
P T-Series TD Door Hinges: just what is the difference between right and left? MG 11
F VIN Problem / Whats difference between BN6 and BN7, bare car. Austin Healey 21
N 3" difference between front and rear track Spridgets 5
R difference between instal of 1500 radiator in 1275 Spridgets 3
T Difference between 1969-74 and later exhausts Triumph 7
B Difference between an HIF6 and HIF44? MG 5
F Difference between disk and wire rotors???? Spridgets 1
T Any difference between brake M/C rebuild kits? Spridgets 18
T TR6 TR6 fans - difference between years? Triumph 0
heliguy TR5/TR250 Gearbox difference between TR4A and TR250 Triumph 8
T MGA Difference between MGA front springs? MG 0
tony barnhill Interesting Difference Between 2 1985 Cars Jaguar 17
M Difference between MK IX and XK 150 Front Brakes? Jaguar 6
J coolant hoses - any difference between them? Triumph 5
J Is there a difference between fenders? Triumph 2
T Quality difference between Moss and VB carb kits Triumph 3
A Headgasket , difference between late and early ?? Triumph 2
frankenstang57 TR5/TR250 whats the difference between a 250 & a 4? Triumph 18
T Difference between a WAX and a Paint Sealant? Restoration & Tools 0
bighly The difference in specification between the models at a glance Austin Healey 2
V MGB Folding convertible vs stow away. What years? How much difference? MG 2
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Got_All_4 General TR Payen brand head gasket sets what's the difference Triumph 10
S TR2/3/3A What's a little thing that made a huge difference in your vehicle? Triumph 37
drooartz MGB Difference in clutch master cylinders? MG 4
K BJ7 interior back panel difference Austin Healey 4
HealeyRick A 100 With a Difference Austin Healey 9
trrdster2000 GT6 Another little difference, big problem. Triumph 11
HealeyRick 100 With a Difference Austin Healey 6
5 Mk1 vs Mk2 front shroud difference Austin Healey 6
J Does a texas cooler make a real difference ? I now am using an a moss flex fan ! Austin Healey 24
T Weight difference beween steel and wire rims Triumph 11
K TR4/4A Difference in Clutch Shafts 4A? Triumph 4
M 3.0 iron weight difference Austin Healey 7
L For those who know the difference Lotus 5
bugedd Difference in 1275 heads? Spridgets 24
S ride difference oem vs poly bushings Triumph 4
H Steering box adjusted, what a difference Austin Healey 0
W Rear wheel cylinders...what's the difference Spridgets 1
Marvin Gruber Plug gap does make the difference Triumph 19
Jim_Gruber Vroom, Vroom-Oh what a difference in handling Spridgets 11
I Battery - does size make a difference? Spridgets 8
W Heater switch/cables - what's the difference? Spridgets 5
livinginthepast The difference a local shop can make vs. a chain.. Spridgets 9
