The difference in specification between the models at a glance
bighly
Austin Healey: The difference in specification between the models at a glance.
(A closer look by our resident Healey guru Jonathan Rhodes (JR) who knows these cars inside - out due to his Dad owning a new model every time one came on the market while us other kids (JSN & CM) parents could only manage a trip on a train and a bag of chips)
Healey 100/4
BN1
May 1953, 4 cylinder, 3 speed, o/d/ign switch positions - o/d in middle of dash, ign to right. No crease line on back of rear wing. Front wing wheel arch smaller i.e.: From trim top (wing to shroud) to centre of arch = 9 1/2" Radiator grille bars in a satin finish. Made 10,030
BN2
August 1955, 4 cylinder, 4 speed, o/d/ign switch positions - o/d to right, ign in middle of dash. Crease to back section of rear wing in continuation of the front wing/door/front of rear wing crease. Front wheel arch trim to arch measures 8" All chrome grille. Made 4,604 including the 'M' spec kit.
100/6
BN4 (2+2) BN6 (2 Seater)
May 1956, 6 cylinder 2,639cc Both models have drum brakes all round. 100/6 grille badge. For a yardstick, up to Dec 1957, all (?) Longbridge manufactured cars had a centre line down the length of the bonnet. October/November 1957 new 12 port cylinder head available + 1 3/4" HD6 carbs. Early cars had a gallery cylinder head and 1 /1/2" carbs. Made 14,436 +/-
Healey 3000
BN7 (2 Seater) BT7 (2+2)
Mk1
March 1959, 6 cylinder 2,912cc Disc brakes to front. Same appearance as 100/6 + boot lid badge 3000. Made 13,650
Mk2
March 1961.Vertical grille slats. New boot lid badge with MkII text. Triple 1 1/2" HS4 carbs. From November 1961 - Centre change gearbox fitted standard. Total made 19,100 ( MKI & MKII)
BJ7
MkIIA
January 1962, Retains original dash and instruments. Wrap around windscreen, quarterlights and wind down windows. Same door exterior handles as BN & BT cars. Reverted back to twin carbs 1 3/4". 48 spoke wires are now changed to 60 spoke in June 1963. Made 6,113
BJ8
MkIII Phase I
October 1963
March 1961, Chassis # 25315 2 x 2" HD8 carbs. Dual exhaust system + extra silencer at rear. Servo std. New wood facia dashboard. Electronic rev counter. Black faced gauges. Up to May 1964 still had pull door handles. Made 1,390
MkIII Phase II
May 1964. Chassis # 26705 Re-profiled chassis at rear under axle. Panhard rod deleted and replaced by radius arms to rear axle. Front swivel pins are now handed left and right to accommodate type 16 calipers. Single front sidelight/indicator gets larger lens. W/W hubs now get 8 tpi from 12 tpi. Push button door handles with external locks both sides.
March 1965. Chassis # 31336 All cars now fitted with separate amber front and rear indicators.
Last car made March 1968. # 43026
Total production 71,987
UnionJack
Bighly,
Some minor corrections to your otherwise very helpful list. BN6 - 2-seater 100-6's - were not produced until March of 1958 and ended in March of 1959 with the introduction of the 3000. All BN6's were made at Abingdon and had the later improved 12-port head. Only Longbridge BN4's had the early gallery head. I own a BN6 that was produced in Aug. of 1958 and it has the ribbed hood. I think some very early 3000's may have even had these hoods. My understanding was that the rib was added as a styling/structural exercise that was later abandoned but used in production until supply was used up.
Thanks for the list and keep up the good work.
Paul
bighly
bighly
Updates welcome. I hope to eventually post this on my website.
Healey 100/4
BN1
BN2
100/6
Healey 3000
Mk1
March 1959, 6 cylinder 2,912cc Disc brakes to front. Same appearance as 100/6 + boot lid badge 3000. Made 13,650 Also of note that some of these cars recieved the ribbed hood probably from leftover BN4-BN6 stock. There was a run of BN7/BT7s that recieved a thermo carb setup eliminating manual choke. The thermo carbs were later abandoned reverting back to manual choke.
Mk2
BJ7
MkIIA
BJ8
MkIII Phase I
October 1963
MkIII Phase II
M TR4/4A Difference between two Oval Air Filters Triumph 3
V MGB Folding convertible vs stow away. What years? How much difference? MG 2
AUSMHLY The difference between GL4 and GL5 gear oils Austin Healey 0
Got_All_4 TR6 Any difference between 69 & 70 camshafts Triumph 3
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Got_All_4 General TR Payen brand head gasket sets what's the difference Triumph 10
S TR2/3/3A What's a little thing that made a huge difference in your vehicle? Triumph 37
K TR4/4A Difference between 4A frames and TR6 frames? Triumph 6
C Price difference between 100-6 BN4 and BN6?? Austin Healey 14
drooartz MGB Difference in clutch master cylinders? MG 4
K BJ7 interior back panel difference Austin Healey 4
M TR4/4A Is there a difference between the "Body" number and the Comission Number? Triumph 8
HealeyRick A 100 With a Difference Austin Healey 9
trrdster2000 GT6 Another little difference, big problem. Triumph 11
P T-Series TD Door Hinges: just what is the difference between right and left? MG 11
F VIN Problem / Whats difference between BN6 and BN7, bare car. Austin Healey 21
N 3" difference between front and rear track Spridgets 5
HealeyRick 100 With a Difference Austin Healey 6
5 Mk1 vs Mk2 front shroud difference Austin Healey 6
J Does a texas cooler make a real difference ? I now am using an a moss flex fan ! Austin Healey 24
R difference between instal of 1500 radiator in 1275 Spridgets 3
T Weight difference beween steel and wire rims Triumph 11
K TR4/4A Difference in Clutch Shafts 4A? Triumph 4
M 3.0 iron weight difference Austin Healey 7
L For those who know the difference Lotus 5
bugedd Difference in 1275 heads? Spridgets 24
S ride difference oem vs poly bushings Triumph 4
H Steering box adjusted, what a difference Austin Healey 0
T Difference between 1969-74 and later exhausts Triumph 7
W Rear wheel cylinders...what's the difference Spridgets 1
Marvin Gruber Plug gap does make the difference Triumph 19
Jim_Gruber Vroom, Vroom-Oh what a difference in handling Spridgets 11
Cookie Difference between 16acr and 18acr alternator Spridgets 1
I Battery - does size make a difference? Spridgets 8
W Heater switch/cables - what's the difference? Spridgets 5
B Difference between an HIF6 and HIF44? MG 5
livinginthepast The difference a local shop can make vs. a chain.. Spridgets 9
D What a difference a trans mount makes! Jaguar 8
F Difference between disk and wire rotors???? Spridgets 1
T Any difference between brake M/C rebuild kits? Spridgets 18
T Front disc brakes make a big difference? Spridgets 5
R Difference in voltage on front lights as per side. Austin Healey 4
T TR6 TR6 fans - difference between years? Triumph 0
E XJR XJ8 Difference? Jaguar 0
heliguy TR5/TR250 Gearbox difference between TR4A and TR250 Triumph 8
N Radiator difference! Spridgets 2
W Does anyone know the difference Spridgets 2
T MGA Difference between MGA front springs? MG 0
S Rotiserrie restore and $$$$ and Marque difference Restoration & Tools 21
R timing difference for 1500 for different years? Spridgets 5
