XJR XJ8 Difference?
erstearns
Been looking at Jag sedans. What is the difference between an XJR supercharged and a similar XJ8? I assume I want an XJR 2004 or later with alum frame, eng etc.
1 XJ8 or XJR? Jaguar 2
wangdango '96 XJR reversed battery charge screw up... Jaguar 2
wangdango '96 XJR alternator issues?? Jaguar 1
D HELP: Need location of 96 XJR BCM Jaguar 2
J 6 cylinder XJR or V8 XJR Jaguar 5
wangdango XJR/x300 heated seat part2 Jaguar 1
wangdango XJR/x300 heated seat part 2??? Jaguar 2
wangdango XJR/x300 performance upgrades? Jaguar 1
wangdango XJR/x300 heated seat problems Jaguar 2
R Fuel overflow on XJR Jaguar 1
F starting problems XJR Jaguar 3
F starting problems XJR Jaguar 1
M 97 XJR Electrical problems...HELP! Jaguar 10
C 2004 XJR Jaguar 2
C Jaguar XJR-15 & BMW M1 Jaguar 3
B Buying my 1st jaguar [1998 XJR] what should i do first? Jaguar 6
P Jag XJ8 starts but then dies right away. Jaguar 4
G FOR SALE - 2002 XJ8 Vanden Plas Jaguar Classifieds 0
M 2004-2008 XJ8 Air Suspension Reliability and Problems Jaguar 0
M Replacement Sub-Woofer for X308 99 XJ8 with Premium Sound System Jaguar 1
M How Do I check Fuel Pressure at Injector Rail 99 XJ8? Jaguar 5
M 99 XJ8 How Do You Troubleshoot Key Transponder Module? Jaguar 0
M Looking for a Vendor to Repair 98 - 2002 XJ8 ECM Jaguar 2
M X-308 99 XJ8 Engine ECU and Chip in Key Jaguar 2
M 4.0 V-8 for XJ8, XK8 and S-Type Differences? Jaguar 1
M Rough Running 99 XJ8 after Overheating Jaguar 42
M 99 XJ8 Thermostat Housing Failure Jaguar 0
M Self Dimming Mirror on 99 XJ8 Jaguar 1
M Sub-woofer Speaker for 99 XJ8 with Premium Sound Jaguar 1
M Intermittent Hard Starting on 99 XJ8 Trouble Code Jaguar 13
M How to Determine Trim Codes for 99 XJ8 Jaguar 3
M IPod Connectivity Kit for 2007 XJ8 Jaguar 1
D XJ8 rides rough Jaguar 5
F XJ8 Dosen't Start Jaguar 5
F XJ8 Dosen't Start FORUM Navigation Questions 2
John_Worthington Stuck valve? 98 XJ8 Jaguar 2
John_Worthington Updating timing chains and tensioners 98 XJ8 4.0L Jaguar 9
1 It's not a classic, but XJ8 or SType4.2 Jaguar 17
1 What's the consensus of the XJ8 up to year 2003 Jaguar 4
S Trans fluid question for 98 xj8 Jaguar 16
T XJ8 Jaguar 2
F XJ8 Tail Lights do not work Jaguar 0
S 2000 XJ8 Starting Problems Jaguar 4
J 2003 XJ8 MYSTERY WATER LEAK Jaguar 2
R 98 XJ8 overheats Jaguar 4
J 2003 XJ8 Soverein seeking input Jaguar 5
B 1998 XJ8 Wiper over-run Jaguar 0
M TR4/4A Difference between two Oval Air Filters Triumph 3
V MGB Folding convertible vs stow away. What years? How much difference? MG 2
AUSMHLY The difference between GL4 and GL5 gear oils Austin Healey 0
