3.0 iron weight difference
mudd
question,
does anybody know the weight difference between the stock iron block and head compared to the aluminum 30. aftermarket on a bj8 ?
Michael Oritt
Both your car and your wallet will be considerably lighter.
Keoke
Hard question depends on alloy mix. But it might reduce the weight close to 40%?
Moss claims their alloy 6-cyl head is 51 pounds lighter than the stock iron one. If you knew the weight of either, you could calculate the percentage weight reduction of alloy and apply that to the block to get a rough approximation.
That's nearly a 60% weight reduction--seems a bit high to me (maybe Moss's figure is a bit optimistic). I'd guess a 30-40% weight reduction with alloy.
BoyRacer
My recollection is that aluminum alloy is about 1/3rd the weight of iron or steel. So a 65% weigh reduction sounds just about right.
J Request for soldering iron recommendation Restoration & Tools 6
tr6nitjulius General TR 11/14/21 British Iron@Petersen Auto Museum Triumph 3
Sherlock Another cruise night, more interesting British iron Spotted 2
tr6nitjulius British Iron @Fairbrook Farms Father's Day 6/16/19 Other British Cars 0
tr6nitjulius British Iron Father's Day 6/16/19 Sunbeam (Rootes) 0
tr6nitjulius British Iron@Fairbrook Farms 6/16/19 British Motor Corp 0
T TR2/3/3A Iron or aluminum plug in top of head? Triumph 2
L The last cast iron 6 port head Austin Healey 9
tr6nitjulius General TR British Iron New Yrs Day vid/pics Triumph 2
aeronca65t "Iron Man" Morgan-racer passes Racing 3
tr6nitjulius British Iron*20 +*3 [pics/vids] Triumph 0
D iron itis Austin Healey 1
tr6nitjulius James Dean Memorial invaded by British Iron Triumph 5
PeterK Repairing cast iron manifold studs Triumph 16
T Back to original, cast iron header. Triumph 16
PatGalvin Valve Guides, Cast Iron Vs. Bronze Triumph 6
I Can someone explain this? Iron oxidation and heat Spridgets 4
T cast iron welding info and repair-FYI Triumph 1
tahoe healey iron bushing removal rear leaf spring Austin Healey 6
eschneider anyone have a cortina 1500 cast iron ex manifold Other British Cars 7
S Big American Iron? Other British Cars 7
T TR4/4A Cast Iron Manifold TR 4A Triumph 2
David_K BJ8 Cast Iron Head Porting Austin Healey 16
Z BN1 Cast Iron Heads Austin Healey 2
M Naval Jelly used on cast iron Restoration & Tools 5
Michael Oritt 100 Flywheel Weight Austin Healey 16
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
T TR2/3/3A Body Tub Weight Triumph 8
X Technical specifications including the maximum technical weight TVR 8
S TR2/3/3A What weight transmission oil in a tr3 with OD? Triumph 13
H MGA MGA engine weight? MG 3
TRMark TR4/4A TR4 Weight Loss Program Triumph 6
banjojambo TR2/3/3A TR3A adding weight to improve handling Triumph 5
R Engine component weight reduction Austin Healey 53
BoyRacer weight of bare Healey chassis Austin Healey 8
T TR2/3/3A TR-4 Tail shaft counter weight Triumph 4
kennypinkerton MGB Body shell weight? MG 3
kennypinkerton MGB Rubber bumper weight surprise.. MG 4
BOBBYR Frame weight Austin Healey 14
T Weight of a Bug-Eye bodytub: approx 220 pounds Spridgets 10
Willie_P TR4/4A Weight Weenies: Tr4 relo of battery to boot...good idea? Triumph 6
glemon General TR Weight Loss Program Triumph 9
GeorgeC Hardtop weight? Spridgets 6
Griz Engine weight Austin Healey 13
2billydavies TR2/3/3A engine fan assembly on TR3a: balance weight question Triumph 3
R weight of BJ8 Frame with inner body panels Austin Healey 1
P 1275 Weight?? Spridgets 3
D Engine weight Triumph 4
O TR2/3/3A TR3 Overdrive Weight? Triumph 6
5 TR2/3/3A TR3 bare shell weight Triumph 9
