Engine weight
TR3driver
Great Pumpkin - R.I.P
I don't have the number handy, but it is comfortably under 500 pounds, which is the smallest engine hoist you'll find.
Based on the fact that I can just barely pick up a bare TR3 block, I'd guess it's around 300 pounds loaded.
Jesus
My TR3A engine weighted 411 pounds (including flywheel and clutch) without distributor, sump, fan, oil filter, oil and water. I have also the figures of all the single parts, if someone needs them.
Jesus
Jerry
I still suggest a 4 leg engine stand. I have had the 3 leg ones fall over when torqueing bolts. Scary! Jerry
H MGA MGA engine weight? MG 3
R Engine component weight reduction Austin Healey 53
Griz Engine weight Austin Healey 13
2billydavies TR2/3/3A engine fan assembly on TR3a: balance weight question Triumph 3
B Engine Oil Type and Weight? Austin Healey 8
vette Engine Weight Austin Healey 19
C TR6 FWIW TR6 engine and transmisson weight Triumph 4
fad64b TR 3, TR 4 engine weight Triumph 3
W Weight of engine and transmission Spridgets 8
A 1500 Engine Weight Spridgets 10
A Weight of Engine and Transmission Spridgets 1
Lucas63 TR4/4A TR4 Engine and Transmission Weight Triumph 5
catfood Engine weight. Austin Healey 5
W 6 cylinder engine weight? Jaguar 5
B engine and trans. weight MG 11
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
