I usually remove the hood completely (I'm thinking that's not a concern on your car, likewise, if your shroud is already off, some of the items listed below can be ignored). If your hood is still on, and assuming it is now correctly aligned, drill two (2) 1/8" holes through each hinge bracket so you can put the hood back in the exact same position when you're done. Make them look neat, and no one will ever notice...
Some things will become obvious as you lift the engine, like having to unbolt the LH motor mount bracket from the block. Getting the RH mount out of the way is a judgement call, but will afford you some extra room.
Remove the radiator, upper & lower hoses and the fan blade(s).
If your car has tubular headers, they and the carbs will need to come off first (a real treat if you're running Webers with a combined air filter box). If you still have the stock exhaust manifolds, they and the carbs can remain in place. I'm pretty sure that the stock air filters do not pose a problem.
Removing the generator can be an advantage. Ditto the wiring for generator, starter and coil (and the electric choke/carb, if fitted).
Shift lever has to come out of the trans (side or centershift, they'll both hang you up). Transmission tunnel removed.
Tachometer cable disconnected from the drive under the distributor.
Heater hoses.
Don't forget to undo the throttle linkage (without losing a grommet in the firewall).
Oil pressure line has to be undone; flexible pipe connection, either at the block or the ridgid pipe.
Water temperature gauge capilary tube (careful with this one).
I suppose the best advice, is to just relax and take your time, always watching 360* around the engine bay for every couple inches of rise.
As long as you can get a solid attachment (no slack or gaps) the two (2) studs that secure the rocker cover are adequate for lifting the mass. The factory did it with L-shaped lifting brackets, but I made a fixture from 2 x 2 angle iron (relieved for clearance, a/r) that bolts atop the rockershaft, and has multiple holes for the angle. It's proven itself worthy dozens upon dozens of times (I worked at a shop specializing in Healeys during the 70s).
If I can think of anything else, I'll add it to the list...
