Engine Oil Type and Weight?
Keoke
BJ7archaeologist said:
I'm in the process of changing my oil on my BJ-7 and I have a bottle of Topco to add. I forget what kind of oil and weight I used last time. Suggestions?
[1] Keep a written log of your cars maintenance.
Leave the "Toco " on the shelf.
Use Valvoline racing-VR1- 40, 50 or 60 weight depending on engine wear.
pkmh
Keoke,
I am using the VR1 20w50 as you suggested to me. I noticed my oil pressure at idle now reading around 50~60 lb. I see you list 40, 50 or 60 depending on wear. Is 40 for more or less wear? If at 50-60 lb, what weight is recommended?
PKMH
TimK
Are you reporting the pressure when cold, or when hot? Cold pressure is usually max at 60 or so. When hot on a tight engine it should be at 40, or 20 with a good but worn engine.
Keoke
pkmh said:
Keoke,
I am using the VR1 20w50 as you suggested to me. I noticed my oil pressure at idle now reading around 50~60 lb. I see you list 40, 50 or 60 depending on wear. Is 40 for more or less wear?---Less wear.
If at 50-60 lb, what weight is recommended?---For a low engine temperature idiling pressure in this range the 50 weight should be adequate.---Keoke
PKMH
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
M new engine rebuild, new type oil seal and LEAKS ?? Triumph 15
BOBBYR ENGINE OIL TYPE ? Austin Healey 7
tr6nitjulius Oil flow view inside operating engine Other Cars 4
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
nevets Oil soaked engine bay Austin Healey 32
T TR2/3/3A What is best way to flush engine after antifreeze got in oil?? Triumph 2
T 1275 engine oil pressure warning light? oil filter warning light?? Spridgets 4
KVH TR4/4A I Can't Stop Burning Oil; Engine Missing at Take Off Triumph 5
S My recent decision regarding oil in a '66 3000 with a rebuilt engine Austin Healey 101
B TR2/3/3A Engine Oil Pressure Triumph 7
H What are the pros and cons for full synthetic oil in a 948cc engine Spridgets 5
H Preferred Motor Oil for 948cc engine? Spridgets 6
gbtr6 TR6 Prime oil pump in rebuilt engine... Triumph 10
M TR4/4A Oil pressure line from engine....assistance please. Triumph 9
T TR4/4A Restarting an engine - oil pressure problem Triumph 6
JPSmit engine oil cooler question Spridgets 11
KVH TR4/4A Removing Oil Canister/Pressure Housing from Engine Block Triumph 5
TulsaFred Front engine oil leak Spridgets 33
David Townsend TR2/3/3A Engine Oil Cap Decals Triumph 0
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
T TR4/4A Any problems with new oil pumps for TR4 engine? Triumph 8
C new engine - oil pressure blowing filter seal Austin Healey 12
J Engine block modification for oil to water jacket leak Austin Healey 8
drooartz MGB At what oil pressure do I need to dig into the engine? MG 21
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
Tim Tucker Front Engine Oil Galley Plug Triumph 10
V TR2/3/3A TR3B Engine Oil Triumph 8
P Engine & Gearbox Oil Austin Healey 3
H Engine oil Austin Healey 4
KVH And for the Engine Oil Leak Triumph 3
memphis Engine Side Cover Plate Oil Leak Austin Healey 15
V How much extra engine oil with oil cooler??? Spridgets 5
F Engine painted! Questions on Oil? Spridgets 27
coj oil pressure 1963 engine [29F] Austin Healey 7
T Oil for an anciente engine Spridgets 3
I oil/oil additives for stock Bugeye engine? Spridgets 10
L Low oil pressure in new engine Austin Healey 67
R flush oil & water pathways in engine Spridgets 4
I bugeye 948 rebuilt engine - no oil pressure, Spridgets 7
doughairfield Oil during engine break in Triumph 6
bighealeysource oil leaking from engine side covers Austin Healey 25
Number_6 TR4/4A Oil Leak on TR4 Engine Triumph 9
beachbumbarry Rebuilt engine oil pump MG 1
M Engine Oil Leek Raising Some Concerns Spridgets 2
pjsmetana Auxiliary Oil Feed to Rockershaft on 1500 engine Triumph 4
roscoe Oil should be INSIDE the engine... Austin Healey 11
MGBGT_noob oil pump for rebuilt engine MG 17
tony barnhill '63 Midget Engine to Oil Pressure Guage... Spridgets 8
Bruce_B Need help with oil pressure on startup of engine!! Spridgets 8
