coolant hoses - any difference between them?
jackag91
I ripped the two manifold hoses last weekend trying to get the intake manifold off of the car.
Is there any major difference between the different hoses available?
I guess I should just go ahead and replace all of the hoses at one go?
PeterK
VB sells Kevlar reinforced hoses. I have them but can't tell you if they're better or worse in terms of strength.
Brosky
Green looks nicer, but maybe only in my opinion.
And Tom's right, do them all. Make sure that you get the twin pipe flange and gasket that go through the firewall and connect the engine hoses to the heater core hoses.
T TR2/3/3A TR3 coolant hoses Triumph 2
PatGalvin TR2/3/3A Coolant System Hoses Slipping Triumph 5
sparkydave Coolant hoses Spridgets 5
BobbyD Bad Coolant Hoses Triumph 11
IanF Spitfire Spitfire coolant hoses... Triumph 2
M XJS V-12 Coolant Hoses Jaguar 6
S Spitfire Cyl head coolant hose fitting Triumph 1
Patrick67BJ8 Coolant Overflow Tank Austin Healey 21
B TR6 Triumph tr6 coolant leak Triumph 4
B Oil (or Coolant) Leak Austin Healey 10
FlyingCat Spitfire Losing Coolant Triumph 12
M TR6 1973 TR6 Coolant Type? Triumph 5
R Coolant temperature gauge Spridgets 8
Govtslug TR6 Coolant Temp Q Triumph 4
K TR2/3/3A Hot day coolant overflow issue.... Triumph 1
nevets Coolant Temperature Austin Healey 13
L BMC A-series: Oil in coolant British Motor Corp 6
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
K TR2/3/3A Radiator coolant level? Triumph 5
M TR6 '72 TR6: Oil in Coolant Triumph 25
W TR2/3/3A location of the coolant drains on a tr3a Triumph 4
Got_All_4 Wedge Tapered coolant hose for a PI car. Triumph 3
Paulus TR4/4A Coolant pressure Triumph 5
D TR2/3/3A Coolant tap on TR3 block Triumph 3
gfholl Coolant Leak Spridgets 9
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
M Coolant 'overflow' when not overheating.... what's up? Spridgets 34
S TR2/3/3A Replacement of Engine Coolant Drain Triumph 3
B All the coolant in the wrong place Spridgets 17
G TR4/4A Thoughts on my coolant Triumph 12
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
D TR2/3/3A Block coolant passages plugged - pull the head? Triumph 46
JFS Wedge Low Coolant Light Triumph 7
Boink Waterless Coolant - thread from the AH forum Spridgets 18
RJS TR4/4A Head Leaking Coolant after Coolant Flush Triumph 15
Jim_Gruber Replacing Spridget Coolant Spridgets 21
T TR4/4A Coolant in the oil - again. Triumph 18
Jim_Gruber Coolant Bypass Nipple on 948 Welded Closed - Advice needed Spridgets 7
P Coolant level indicator wrong? Jaguar 4
T TR4/4A Oh crud - coolant in the oil Triumph 33
W Waterless Coolant Austin Healey 4
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
RAC68 Waterless Coolant Austin Healey 29
B TR2/3/3A coolant expelled Triumph 14
Keith_M 1275 burning coolant Spridgets 20
S Coolant Loss Spridgets 32
S Air/Fuel Mixture affect on Coolant Temperature? Spridgets 2
M oil in coolant Austin Healey 16
M TR4/4A Coolant. Triumph 7
mgedit TR2/3/3A Coolant spit out of overflow Triumph 20
