Clutch problems
ichthos
Help! I wrote earlier about not being able to get my car into gear while the engine is running. I bled the clutch system a number of times now. The pedal eventually gets stiff, and then within minutes gets loose again. I replaced the slave cylinder. I rebuilt the clutch master cylinder. I don't know if it makes a difference, but the slave cover gets pushed off when I depress the pedal a few times. I am figuring it still has to be the slave cylinder or master cylinder that is not working. Can anyone tell me how to tell which one is the culpret? Is there something else I am overlooking? This is the last problem to deal with for me to make my first test run after working on this car for the past year.
Thanks, Kevin
vettedog72
Are you loosing fluid out of the system? Do you have a balloon effect on the line from the master to the slave? If not, have some one look at the master reservoir when you push in the clutch. The fluid level should drop. If the master is leaking, the fluid level will come back up even though you keep the clutch pedal on the floor. If the level does not increase, then I would suspect the slave. After the big work you did on the pin, disk, bearing etc., I am glad to hear the problem is on the "out side".
I
ichthos
Thanks for the help. There is no fluid leaking. I did not notice a ballooning effect, but I wasn't watching very carefully last night. Considering the hose is 25 years old, it is certainly a possibility. I'll try your suggestion about observing the master cylinder also when I have help tonight. My first guess (hope) is that it is the master cylinder.Thanks again for your help.
Kevin
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
H Continuing clutch problems Austin Healey 10
H Continuing clutch problems Austin Healey 7
Lukens TR2/3/3A My theory about my clutch hydraulic problems Triumph 11
Lukens TR2/3/3A Clutch hydraulic problems Triumph 12
Lukens Clutch master problems Triumph 23
mdionne Clutch Problems Spridgets 6
bobmga62 T-Series MGA clutch problems MG 12
JKent TR6 TR6 clutch problems Triumph 16
eschneider T-Series Clutch - shifting problems - help? MG 19
S Clutch bleeding problems Spridgets 19
B T-Series CLUTCH BLEEDING PROBLEMS MG 9
M Clutch Problems... Triumph 4
D Clutch Problems Spridgets 13
C Clutch problems Triumph 2
S Wedge TR7 Clutch Problems Triumph 2
S Wedge Clutch Problems - TR7 Triumph 4
7 T-Series 1976 midget clutch problems, please help me. MG 17
N T-Series more clutch problems MG 2
F TR6 TR6 CLUTCH PROBLEMS-AGAIN Triumph 4
T CLUTCH PROBLEMS HELP NEEDED!! Triumph 2
M Wedge tr7 clutch linkage problems Triumph 0
W T-Series Does this sound like clutch problems? MG 7
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
Michael Oritt Clutch Linkage Austin Healey 19
