General Tech Clutch trouble
Trevor Triumph
My 1964 Spitfire has clutch issue. The transmission is a single rail with over drive. I thought the problem was hydraulic cylinder related. Annoying sounds putting the transmission in gear at a stop sign / signal, yet rather silent changes through the gears.
I've replaced the cylinder washers and even a new slave cylinder and master cylinder. Whem bleeding the sytem, the clutch pedal goes to the floor on only the first or second push. After that it stops maybe two inches from the floor and when the bleed nipple is open, the pedal goes to the floor. Rather like bleeding the brake pedal.
I'm wondering if the problem isn't in the cltuch assembly. I can push against the pin and with effort the clutch fork moves. I don't remeber when I replaced the clutch, but seems there are not a lot of miles since the last replacement, though probably several years.
I may have to resort to a pro, time is running out. We plan to attend Triumphest with this car.
Any thoughts?
sp53
is there any chance you have the disc in backwards or flipped. I did that once on a spitfire and the clutch stopped before it hit the floor. The reason being one end on the disc has a flange that if put in backwards hits the plate.
steve
T
Trevor Triumph
I wonder fif that sort of thing could be a problem... Things woked well for quite a while, then there was trouble getting into first gear after a stop. Shifting through to fourth and OD went without ugly sounds. As I drove further the problem grew worse, until I couldn't shift into reverse or first. Now the car moves with the pedal as pushed as far as it will go.
sp53
If the clutch worked well for a while then I would say the problem is in the hydraulics. If you have replaced the master and the slave and bleed by gravity, perhaps the hose to the slave is folding in on itself. The system is simple and new parts usually fix it. If you rebuilt the hydraulics then perhaps the inners are shot, go with new.
steve
CJD
It sounds like a bleeding issue.
Try cracking the bleeder just 1/2 turn with a clear hose on the bleeder. Allow gravity to bleed the system until no bubbles are seen exiting the bleeder. Do not pump the pedal while bleeding, but ensure you have enough fluid in the reservoir.
bobhustead
I deleted a prior comment which was mistakenly based on TR3 components. I don't know much specific to Spits. But, this is a clutch actuation/hydraulic issue. The hard stop 2 inches above the floor is an indication that something is bottoming out. The fact that it goes to the floor on opening the bleeder likely indicates the bottoming is at or after the slave. May relate to binding of the throwout fork or some movement point in it. Is it possible that the piston in the master is reversed? I also notice in the catalog that there are two diameters for the slave. Did you get the right one when you did the master and slave replacement?
Bob
bobhustead
Looking more at the diagram in the Moss catalog, your symptoms might also be consistent with failure of the throwout fork fulcrum, items 38, 39, and 40 in the Moss diagram.
Bob
T
Trevor Triumph
Yes, all the cylinder stuff seems to work properly. The transmission is coming out next Monday 8\14. In the meantime I get to clean / degrease stuff over and around the transmission. It should be ready for Triumphest in September.
T
Trevor Triumph
At last the Spitfire will be on the road. The problem wasn't the master or slave cylinder. Apparently the "slop" in the pin the the slave cylinder pushes against had a lot of wear. The pin was worn, the throw out bearing carrier was worn, the clutch fork fulcrum pin was worn. I'm thihking there was probably one fourth of an inch free play. All those bits were replaced, and intitial test suggests success. Tomorrow comes the ultimate test.
T.T.
CJD
Interesting. If you follow the service manual, it tells you to take up all the play until you have a solid linkage, and then back off the specified amount. That accounts for normal wear. Over the years I think clutch adjustment eludes the most number of owners!?!
T
Trevor Triumph
I know I have read about adjusting the clutch in TR series, but never with a Spitfure. I've read the Haynes manual several times - I've had the -transmission out several times due to ineptitude on my part. According to other sites, the hydrauloic clutch is "self-adjusting."
CJD
I know nothing about the Spitfire...except the clutch is obviously not self adjusting, LOL.
sp53
My wife had a 1971 spitfire in 1974 so it was a kind of a new car. I blew the motor racing around and pulled the motor and trans. When I put it back together with a new clutch, the clutch would not disengage. I did not know what to think because there were no adjustments on the slave or master. I called around and was told to get in and start driving and the pressure plate would wear down and fix itself. I did it and it worked--- sounds like your problem was the opposite. You had so much play from the non- adjustable parts being wore thin your clutch would not engage. Perhaps this is what they mean by self adjusting.
steve
G TR6 Clutch trouble Triumph 4
RickB MGB Trouble bleeding new clutch MC & slave MG 6
bluemiata90 TR6 TR6 CLUTCH PIN OR HYDRAULIC TROUBLE Triumph 6
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
T Clutch Pedal Engagement Point Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
K TR2/3/3A Clutch slave "return spring"? Triumph 3
vintagemechanic Recommended clutch kits Jaguar 3
K TR2/3/3A Clutch Master Cylinders? Triumph 1
R TR2/3/3A Clutch Engagement Triumph 31
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
T TR2/3/3A TR3A clutch problem Triumph 15
S MGB 1978, replacing the clutch. MG 3
S MGB clutch replacement MG 7
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
D BJ7 Clutch Austin Healey 6
K TR2/3/3A An Unusual Brake and Clutch MC Set Up? Triumph 2
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
