Clutch in or out at stop - survey
AUSMHLY
I was talking to a friend of mine the other day about there are two types of people who drive a stick. Ones that at a stop, put the car in first and hold the clutch in and those who put the car in neutral and release the clutch.
Then the conversation went to is it OK to keep the clutch in at a stop. Comments on that?
So Healey owners, how many of us keep the clutch in or out?
Cheers, Roger
Well Roger, if you or your friend, just love pulling the tranny to replace throwout bearings or a clutch then by all means put the car in second and hold the clutch in when stopped at signals. /ubbthreads/images/graemlins/yesnod.gif Seriously, use this method as little as possible---Keoke-/ubbthreads/images/graemlins/yesnod.gif
My friend would do this in his modern car, and I found it a great effort to keep from saying anything each time. That, and I can't understand how one doesn't find it uncomfortable to keep the clutch down constantly.
[ QUOTE ]
Cheers, Roger
[/ QUOTE ]
Healeys & a few other cars use a carbon face throwout bearing. It has no actual bearings in it. See attached pic. The small part, throwout bearing, only has a carbon face that bears on the metal ring on the clutch release levers, or diaphram on later models.
Every time that the clutch pedal is depressed, a small amount of carbon wears off. The linkage should also be adjusted with enough free play to prevent bearing contact with the clutch when the pedal is out. The less time you push on the clutch pedal, the longer the carbon bearing will last.
HI 100-6, yes it can be very uncomfortable holding a big Healey clutch in.However, talldrivers ,like myself sometimes are forced to ride the clutch in heavy traffic.The lost motion and time getting your foot on the clutch can result in a collision. Modern cars with their ballbearing throwout bearings are less susceptible to wear and subsequent failure although they sometimes do fail.---Fwiw---Keoke /ubbthreads/images/graemlins/driving.gif
--- /ubbthreads/images/graemlins/savewave.gif
PS, I wish you would not post a photo of your neat well organised shop because mine looks worse than a junk yard!
Clutch out for me! Although my MGB has a rare aftermarket roller throwout bearing!
Interesting to discover yet another English / US English word usage difference - it's always been a 'clutch release bearing' over here.
As for riding the clutch - absolute no-no both for mechanical reasons and safety reasons.
Throw the clutch out of engagement = release the clutch grip by pushing the pedal. As opposed to release the pedal which engages the clutch. IMO, throwout is more accurately descriptive. Whereas, release the pedal engages the clutch. We are still separated by a "common language".
D /ubbthreads/images/graemlins/frown.gif
[ QUOTE ]
When my daughter was taught to drive she was told to hold the car on slight hills by using the clutch ! arrrrgh !
[/ QUOTE ]
Did her Daddy teach her? On the Healey? /ubbthreads/images/graemlins/devilgrin.gif
For some masochistic reason my daughter wants ME to teach her.... I can't imagine anyone that would be worse....
While I'd undoubtedly make all sorts of foul ups in it, I'd not do that clutch trick....
clutch out always, even in stop & go traffic...a little trick someone taught me a long time ago - when idling at a stop light with the clutch out, as soon as you see the opposing light turn amber, depress the clutch and slip her into first gear...the instant the light turns green, you're ready to roll. I still do this. ofcourse this was before the advent of delayed green.
Transmission in neutral, foot off the pedal, for all cars. Not only for the sake of the bearing, but also the disc lining wears only when disengaged. AND, the forward thrust you are exerting on the crankshaft thrust washers is extreme. Modern cars with "safety" switches are forcing you to push the crank forward before starting (and oil pressure).
Now, how about engine braking?
Transmission in neutral, foot on the floor, for all my vehicles. I put the car in first when I see the opposing light turn yellow. Hey, do you think we could induce a manufacturer to make a ballbearing throwout bearing? It is "out of sight." Would there be a big advantage?
I was told that in the early days England used a yellow light in their traffic signals both before red and before green so you had notice when the light was about to turn green so you could release your emergency brake and put the car in gear. I have roller bearings in a couple of my LBC's but I still use clutch out.
John
Dar,
Ball bearing release bearings are available aftermarket for some models. They are sometimes used with ultra stiff competition clutches. Pretty expensive though. The owners of some marques seem to be on an endless search for a better ball bearing release bearing, so just converting is not a sure fix either. The carbon type will last 90,000 miles or more if it is not "abused" & if it is adjusted to not be engaged when the pedal is not operated.
As Peter said, the crankshaft end thrust bearing will thank you also. Ever notice the engine idle slowing a bit when the clutch pedal is depressed. This is due to the friction load on the throwout bearing & the crankshaft thrust washers.
[ QUOTE ]
Dar,
[/ QUOTE ]
Look at the clutch release bearing assembly for a 6 cylinder 2.6 litre Landrover - you'll find it is almost identical in layout to the Healey one except instead of the graphite surface there is a thrust race. Incidentally the distributor (except for advance curve) and oil filter assemblies are also the same as the BJ8
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
K TR2/3/3A Clutch Master Cylinder "Stop" Bolt.... Triumph 4
K TR2/3/3A TR3A Clutch MC stop bolt and clutch slave adjust Triumph 5
Lutz Kramer Clutch Disengagement Austin Healey 14
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
3 100 Clutch Freeplay Austin Healey 7
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
T Clutch Pedal Engagement Point Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
K TR2/3/3A Clutch slave "return spring"? Triumph 3
vintagemechanic Recommended clutch kits Jaguar 3
K TR2/3/3A Mystery Clutch MC? Spitfire....TR4....69-70 TR6??? Triumph 2
K TR2/3/3A Clutch Master Cylinders? Triumph 1
R TR2/3/3A Clutch Engagement Triumph 31
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
T TR2/3/3A TR3A clutch problem Triumph 15
S MGB 1978, replacing the clutch. MG 3
S MGB clutch replacement MG 7
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
D BJ7 Clutch Austin Healey 6
