TR2/3/3A TR3A Clutch MC stop bolt and clutch slave adjust
karls59tr
Bronze
Is there a set length to the bolt stops in the MC box for the TR3? I believe I have my new clutch master cylinder and slave cylinder adjusted pretty close but the pedal returns about 80% of the way then hesitates returning all the way back to resting position sometimes. Unless I have to adjust the threaded rod on the slave a little more? Also there are three holes for the return spring on the anchor plate. When is that needed for adjustment? And the shaft also has three holes .....is the middle one used most commonly and at what point would you go to the top or bottom one for adjustment?
martx-5
Re: TR3A Clutch MC stop bolt and clutch slave adjust
The only place I've ever seen the slave rod positioned is in the center hole. Which hole you use for the return spring probably wouldn't make much difference, as the are all pretty close together IIRC.
If the pedal is having trouble returning all the way, check under the dash by the pedals. There are return springs for both the brake and clutch pedals that have a habit of breaking...especially the clutch pedal return spring.
The pedal adjustment screws on the outside under the bonnet just adjust the final returned position. They should be adjusted to give about .030" clearance between each push rod and the piston in the master cylinders. This free movement can be felt at the pedal when depressed gently by hand. Normally, they never have to be changed unless you had the whole assembly apart.
Harry_Ward
In addition to what Art mentioned another possible reason the pedal doesn't return all the way is rust build up in the pedal shaft bushings or pedal shaft of both the brake and clutch pedals. The linkage to the pedals will need to be removed to the master cylinders and the pedal assembly's will need to be removed. The pedal shaft and pedal shaft bushings will need to be cleaned and oiled. You will know this is the problem if either pedal when depressed individually makes the other pedal move. clean the pedal ends on the flat as well because this could cause the pedals to bind.
K
karls59tr
Bronze
Thanks for the info Harry. So if the stop bolt has been changed out by the previous owner,and its a slightly different length ,it shouldnt matter as long as there is the 30 thou clearance?
Don Elliott
I had the clutch pedal arm hang up on the return and found out that the cross pin in the end of the clutch master cylinder push-rod had worn about 1/2 way through. This was causing the hang-up. I happened to be in Virginia at the time, but I had a spare one. After changing it, the problem was resolved.
Harry_Ward
I was just told in no uncertain terms that I must depart the forum to go buy window shades... Lucky me. Anyway the Ball book states, Unscrew the adjusting screw together with the locknut until a .030 inch feeler gauge can be passed between the locknut and the support bracket. Without allowing the adjusting screw to turn, screw the locknut to lock the screw. This is the adjustment description for a <span style="color: #FF0000">Lockheed brake system </span>on a TR3.
For the <span style="color: #FF0000">Girling</span> system the master cylinder piston plunger must be fully extended out at it's end of travel. Then adjust the locknuts on the pushrod so there is always 1/2 to 5/8ths inch free play on the pedal travel before the piston plunger begins to operate. This is the setting for both the brakes and clutch master cylinder setting <span style="color: #FF6666"> </span> .
T TR2/3/3A TR3A clutch problem Triumph 15
C TR2/3/3A TR3A clutch/brake cylinder rebuild Triumph 4
angelfj1 Wanted '59 TR3A Clutch Master Cylinder - USED, RE-BUILDABLE, NOS Triumph Classifieds 4
angelfj1 TR2/3/3A 59 TR3A Clutch Master Cylinder Failure Triumph 19
K TR2/3/3A TR3A with TR6 trans Clutch Bleed Issue Resolved. Triumph 6
K TR2/3/3A TR3A Clutch Slave Bleed Issue? Triumph 8
M TR2/3/3A TR3A clutch hydraulic problem Triumph 9
T TR2/3/3A TR3a Clutch Pedal Return Triumph 2
K TR2/3/3A Complicted Clutch Slave Problem TR3A Triumph 12
M TR2/3/3A TR3A Clutch Bleeding Triumph 17
L TR2/3/3A TR3a Clutch cylinders Triumph 16
K TR4/4A Can I put a TR3A Clutch in a 4A? Triumph 16
M TR2/3/3A Position/Adjustment of TR3A Clutch Slave Cylinder Triumph 20
T TR2/3/3A TR3A clutch&brake master cylinders Triumph 11
H TR2/3/3A TR3A Clutch Ratteling Triumph 3
Tinkerman TR2/3/3A TR3A Post 60000 Clutch M/C to Reservoir Line Triumph 6
H TR2/3/3A TR3A clutch ratteling Triumph 2
Tinkerman TR2/3/3A TR3A Clutch Pressure Plate Triumph 2
K TR4/4A TR3A and TR4A clutch pressure plate...Difference? Triumph 2
NutmegCT TR2/3/3A clutch pedal "snap" - TR3A Triumph 9
MGTF1250Dave TR2/3/3A TR3A Clutch Hydraulics Triumph 8
MGTF1250Dave TR2/3/3A Help with TR3A Clutch Slave Cylinder Triumph 3
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
