Put the kits in the bugeye carbs. Just now bolted them back on and the front one leaks. Poured gas in the float bowl and the float floats. Used the 7/16 dowel and it appears the yoke is seating the float needle. When installing the kits there were small beveled washers that were hard to orient according to the manual diagram. Is it possible I reversed those and gas is leaking past them? It's really hard to tell where the leak is. Gas just runs out the bottom from someplace. What would you do?
