tweety
Hi all,
I've got a 79 midget with Zenith carb, CA emmissions.
I've owned the car for a little over a year and am still finding all of the bastartizations committed by PO's. The carb being one of them. The water choke has never been hooked up (just hanging there by the hoses) it appeared that a conversion to a manual choke had been started by never finished. I just discovered that the choke assy that was once attached to the carb is gone! Seems to have just fallen off and vanished.
Car still runs though!
Second problem is that the plug at the bottom of the float bowl is leaking gas. I understand that there is an o ring that often corrodes away.
Q: I'm wondering if I can get it out (the plug) and replace it without pulling the carb. I see that Moss sells a plug and o ring. I would love to be able to do it w/o pulling the carb. I'm looking for words of wisdom here.
Q: Given the constant overall issues with the Zenith carbs, any suggestions on what to replace it with? It's gonna cost some $ to restore the choke, I don't mind spending a little more to have this whole issue fixed right.
Thanks guys, I can't tell you how much I've learned from all of your posts.
