carb advice please
tweety
Hi all,
I've got a 79 midget with Zenith carb, CA emmissions.
I've owned the car for a little over a year and am still finding all of the bastartizations committed by PO's. The carb being one of them. The water choke has never been hooked up (just hanging there by the hoses) it appeared that a conversion to a manual choke had been started by never finished. I just discovered that the choke assy that was once attached to the carb is gone! Seems to have just fallen off and vanished.
Car still runs though!
Second problem is that the plug at the bottom of the float bowl is leaking gas. I understand that there is an o ring that often corrodes away.
Q: I'm wondering if I can get it out (the plug) and replace it without pulling the carb. I see that Moss sells a plug and o ring. I would love to be able to do it w/o pulling the carb. I'm looking for words of wisdom here.
Q: Given the constant overall issues with the Zenith carbs, any suggestions on what to replace it with? It's gonna cost some $ to restore the choke, I don't mind spending a little more to have this whole issue fixed right.
Thanks guys, I can't tell you how much I've learned from all of your posts.
Platinum
While ya do that, Duncan, I'll offer up my 2p:
Yup. It ~can~ be done with the carb in-situ... but only by a contortionist with small fingers and a lot of patience. The bowl can be lowered from the body by removing the six screws, lower bowl... empty, clean, pop out th' plug and renew th' O-ring, refit the bowl (being aware of the float now dangling in th' ether) and TRY to reinstall the screws.
It's just easier to bench the carb and go thru it that way. The manual choke idea isn't a bad one, IMO it eliminates one more potential water leak AND a "funky" piece of engineering.
My opinions only. :wink:
tosoutherncars
https://www.britishcarforum.com/bcforum/ubbthreads.php/topics/467017/1
(Link to original post and various carb resources) Have a look at the bottom of that discussion, there are a couple of links specific to problems with the water choke, and rebuilding it.
I've got a Midget with the same engine (78 California 1500.) The original CD150 is notorious for running very, very rich for a number of reasons, including the horrible water choke.
In increasing $ / time / hassle, I would suggest a few options:
- rebuilding the choke and carb, and resetting both
- upgrading to either an electric or manual choke
- Ditch the carb, keep the stock manifold and run a single SU. (Probably what I'd sugest for someone on a budget, with fair mechanical abilities.)
- Ditch the carb and manifold, and replace with a Weber DGV (What I did)
- Ditch the carb and manifold, find a dual SU setup (Nice, looks great, good power & parts support, looks stock, requires a little sheet metal work)
- Ditch the carb and manifold, go for an aftermarket dual DCOE setup (fairly big $$)
I was so frustrated at mine that I replaced the whole thing with a Weber DGV (electric choke) which has been fantastic so far. Better starting, increased power, easier to adjust, sounds great. Kits on ebay for about $300.
Woodie
as my friend Duncan says he has the dgv, while I have the twin SU's...so easy to get right, they were the best carbs for the 1275 bar none. I have rich M needles in mine thanks to a fine gentleman in the UK who rebuilt the set I have and then sold them to me. And as far as sound, try putting a pipe to the erar with a single resonator and no sideways muffler. Then go for a run and down shift and listen to the burble..sweeeeeet!!
C Some carb advice please. Austin Healey 9
Shinsen774 Front SU Carb Leak - Advice? MG 19
F Wedge 1980 TR7 ZS Carb rebuild advice [need some] Triumph 5
A Hi I'm New here , Need Advice on SU Carb Filters Triumph 0
A Hi I'm New here , Need Advice on SU Carb Filters Triumph 5
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
E MGB SU CARB OIL 1965 mgb MG 3
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
D Tri carb: order of installation question. Austin Healey 5
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
E MGB SU carb air cleaners MG 10
Healey Nut Tri-Carb Project Austin Healey 213
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
tahoe healey Dumb carb question Austin Healey 23
jfarris TR2/3/3A Happy with my Paltech Carb rebuild Triumph 8
2 TR2/3/3A SU carb. Acts like an expansion valve ! Triumph 10
dbenichou289 TR2/3/3A SU carb linkages Triumph 2
