BN1 Overdrive
B
Bentley3
I have a friend's BN1 in my shop with an overdrive problem that I have not seen addressed, or if it has, I've missed it.
The overdrive works. The problem is it works all the time. About 20-25 mph the overdrive kicks in, in second or third, as it should, albeit at too low a road speed. It does this regardless of the position of the dash switch. There is no kick-down. The overdrive solenoid will kick out under 20 mph when the shifter is put in neutral.
I have done the following tests according to the factory manual and several on-line procedures: Checked the relays; this is a two-relay system. They are operating as the various tests indicate they should. Tested the gear switch, both in and out of the gearbox. Checked the throttle switch and carefully adjusted it...several times. The test on the switch seemed to be a bit inconclusive so it disconnected it. I tested the overdrive operation with the throttle switch wires both off the switch and connected together without change in the overdrive operation. The centrifugal switch had been bypassed some years ago and the system was working properly until last fall. I removed the bypass to check the centrifugal switch operation without any change. The dash switch is new and I have checked its operation also, knowing that even new electrical components might be faulty. The solenoid is working very well, obviously. The owner bypassed everything and wired the dash switch directly to the solenoid so the car can be used with and without the overdrive, engaging it when needed. Of course, there is no kick-down and he has been careful to turn the switch off before using reverse...so far.
Most all the on-line discussions i've read concern a system not working. This one won't stop working. Any clues as to what I've missed? Suggestions are greatly appreciated.
Have you checked to see that power to the solenoid is being applied/removed when the solenoid activates?
Maybe the solenoid is powered all the time and the OD is switching off the centrifugal switch only.
Power to the solenoid switches on as soon as the gear lever is moved to 2nd or 3rd gear. Maybe it's picking up that power through the centrifugal switch? It's been bypassed with a wire across the terminals but not otherwise isolated.
If the switch is bypassed with a wire across the terminals then it is no longer a switch it’s just a wire junction .
I wrote an article on the BN1 overdrive electrical, soon to be published in the HEALEY MARQUE magazine. I made a logic diagram for the BN1 wiring (attached). You will see the overdrive solenoid is energized through overdrive relay #1 contacts C1-C2. Is relay #1 picking up when the gear lever is in 2nd or 3rd? Perhaps the relay contacts C1-C2 are welded closed? With the wiring modifications, maybe there is some errors in the connections. Looks like the solenoid is always energized and the overdrive enables when the pressure builds up?
C BN1 Overdrive drain plug question Austin Healey 0
G Austin-Healey BN1 Overdrive Challenges Austin Healey 5
M BN1 - Questions about tracing overdrive faults Austin Healey 16
A 1955 BN1 overdrive relay Austin Healey 3
M BN1 Overdrive discovery Austin Healey 12
B Wanted Early BN1 Right Hand Sidescreen Austin Healey Classifieds 0
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
J For Sale BN1 project car (price reduction) Austin Healey Classifieds 0
W BN1 Steering Box Removal Austin Healey 11
W BN1 Steering Box Austin Healey 3
I Wanted BN1 with H6 carbs : bodies of TR3 Austin Healey Classifieds 1
S BN1 Wheel-Tyre Combination Austin Healey 10
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
W Healey BN1 Ignition Light Austin Healey 8
T Wanted: Early BN1 Sidescreens Austin Healey 2
Guido36 BN1 with Triumph TR 4 engine Austin Healey 1
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
W BN1 Gearbox First Motion Shaft Austin Healey 0
I Austin-Healey BN1 Parts List Austin Healey 4
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 25
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
red57 Interesting BN1 for sale in Bellingham, WA Austin Healey 4
D BN1 Parts to Trade Austin Healey Classifieds 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
A BN1 Mechanical Brake Switch Austin Healey 23
P Wanted BN1 can shaft Austin Healey Classifieds 0
C BN1 Clutch Pedal Rattle Austin Healey 2
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
Guido36 BN1/BN2 Sidescreens Austin Healey 0
M BN1 Loss of Power Austin Healey 21
L Seat position for a BN1 Austin Healey 0
CharlesBN1 Wanted WTB Shelley Jack [6 INCH DL] for Early BN1 Austin Healey Classifieds 0
M BN1 with H6 carbs : what setting ? Austin Healey 56
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
M Heat-related carb issue on BN1 Austin Healey 7
RCarr 1954 BN1 Wiper Wheelbox and Rack Austin Healey 3
CharlesBN1 Wanted wanted to buy - sidescreen trim/strips for early BN1 Austin Healey Classifieds 5
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
Michael Oritt Optimal lighting for a BN1 Austin Healey 5
D Wanted BN1 LH Seat Cushion [Bottom] Austin Healey Classifieds 0
J 100 bn1/bn2 id Austin Healey 26
HealeyRick Wilwood Discs on a BN1 Austin Healey 1
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
Z For Sale 1954 Austin Healey 100-4 BN1 Beautiful Restoration Austin Healey Classifieds 0
Z For Sale 1955 Autsin Healey 100-4 BN1 and 1956 100-4 Race car Austin Healey Classifieds 0
D Wanted BN1 or BN2 Donor/Parts Car Austin Healey Classifieds 1
GeorgeC Rear spring disassembly - BN1 Austin Healey 1
Jake BN1 Front Shroud Badge - What is original? Austin Healey 4
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
