Hi.
I'm currently trying to understand what's happening in my new (for me...) BN1, esp. regarding overdrive.
Since I bought it, OD has been out of service, and I think that it is linked to an electrical issue (blown fuse). I've checked the throttle switch and the two relays R1 and R2 w/o finding any fault, but when it went to two other components, it wasn't the same fun :
1) top gear switch (on the 'box) : whatever the gear lever's position - 2nd, 3rd, as for any of neutral, 1st or reverse - there's no contact between the two terminals, so I conclude that the switch is always open and therefore faulty --> Am I correct ?
2) OD solenoid : it doesn't react when directly feeded by 12V between its wire and its body (except sparks at the junction...), and offers the same resistance (i.e. none) with the plunger in low or high position, so I conclude that one of its internal windings is shorted/grounded --> Correct ?
3) I also guess that in this case, it could be the cause of the fuse blowing, still correct ?
In addition, during these tests I noticed 2 other curious fittings :
4) on the right side of the OD, there is some slack (rotation) between the lever used for valve setting and the shaft, because (I think) the split pin securing it is of too small diameter. I suppose that matters for a centering use, right ?
5) on the left side, there's no stop screw under the operating lever (actuated by the solenoid plunger) : I'll try to fit one, but is there any chance that it might have caused an issue in the OD operation ?
Sorry for all these - maybe stupid - questions, but I'm in a fix...
Thank you in advance for your help.
Matt
Matt
