I remember wrestling with my TR3 head to break it loose from the block, but I'm absolutely amazed that I can't free the TR6 head from the block. I've removed everything -- head bolts, alternator/belt, water pump, exhaust and inlet manifolds, air breather (which nicely blocks one of the head bolts), thermostat, and a bunch of other parts. The only thing left in the head (other than valves/springs and the three valve cover studs) is the heater valve tube. I took off the control itself, but the tube has nothing to grab to remove it.
...I attached one of the engine lift points to the head and am using my engine cherry picker and all I've been able to do is to get enough separation to get a scraper in. No pry bars are working to get good leverage. I can literally lift the car off the ground by the head.
Any ideas? I'm running out of patience and blood from knuckles.
Sam
Sam
