TR6 Suggestions: cylinder head won't release from block
sammyb
I remember wrestling with my TR3 head to break it loose from the block, but I'm absolutely amazed that I can't free the TR6 head from the block. I've removed everything -- head bolts, alternator/belt, water pump, exhaust and inlet manifolds, air breather (which nicely blocks one of the head bolts), thermostat, and a bunch of other parts. The only thing left in the head (other than valves/springs and the three valve cover studs) is the heater valve tube. I took off the control itself, but the tube has nothing to grab to remove it.
...I attached one of the engine lift points to the head and am using my engine cherry picker and all I've been able to do is to get enough separation to get a scraper in. No pry bars are working to get good leverage. I can literally lift the car off the ground by the head.
Any ideas? I'm running out of patience and blood from knuckles.
Sam
M_Pied_Lourd
Sam, have you removed the studs or just the nuts off the top of the studs?
S
sammyb
Just the nuts...am I a moron and didn't look to see that the head studs need to be removed entirely???
Geo Hahn
If the studs are still in then perhaps an overnight soak with PBlaster would help -- but probably not help enough to solve everything.
Some have resorted to the 'rope trick' (recently discussed on the crank bolt thread). In this version rope is stuffed into 2 cylinders (perhaps 2 & 5?) approaching TDC until the engine cannot be easily turned. At that point it is turned with some force with the hope that this will lift the head. Even a small movement at this point is often enough to get it loose enough for more conventional methods.
The extreme version of the rope trick would have one bumping the starter once the pistons are fully jammed against the rope & head. I have done this on a TR3 where the main concern was whether the liners would pop loose. Not an issue for you but possibly other concerns on a 6. IOW, use at your own risk, YMMV, etc.
M_Pied_Lourd
The head tends to rust to the studs. Double nut them and try to remove them or use a stud remover. Should come off with no issues then.
glemon
I was struggling with the same thing with a spare TR6 motor I had, there was a piece still attached holding it on or blocking it, I felt stupid when I figured it out after a lot of sweating and grunting, and still a little sheepish because I can't remember what it was now, but triple check to make sure everything is taken off and out of the way, as I re-read your post sounds like the exact same thing, it would lift a little, I though it might be binding on the studs, so took a few out, it turned out to be hitting a part I didn't think was in the way, but I can't for the life of me remember what it was.
titanic
As others have mentioned, the studs grow to the head and make it difficult to remove. After removing as many studs as possible by double nuts, try the rope trick. You mentioned removing the water pump, but the housing that bolts to the front of the head should be removed as well as the water pipe that connects to it. Before re-installing the studs, coat them with anti-seize compound, it will make head removal much easier next time. Yes, there will probably be a next time. Berry
S
sammyb
I removed the water pipe housing. I'm guessing that the studs are the culprit. I'll try to remove them tomorrow with the double nut trick. I was aware of the age-old rope trick, but given the amount of force I'm able to exert on it with the engine hoist, I was afraid of breaking a piston/con-rod.
I'll have at it tomorrow with some PB Blaster (already a can sitting on the car from the spark plug seize that started this whole thing!) and then come back to remove the studs. I'll let y'all know how it goes.
Thanks everyone for your tips. It's been a couple of years since I've done Triumph heavy mechanicals, so it's going to take me a while to get back into the groove.
S
sammyb
My god, what a PITA!!! It turned out to be the two passenger-side studs closest to the firewall. I couldn't remove them, so after another few hours of prying, heating with a torch, PB Blasting, moving the engine hoist from point to point, using the sling, breaking an exhaust stud...it's finally liberated from the car.
As soon as I stop sweating, get some water and food in me, and catch my wits, it's off to the machine shop.
I Bugeye valve rebuild suggestions Spridgets 8
D Shop lighting suggestions. Restoration & Tools 8
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
nichola TR6 Oil pan is going to leak: suggestions? Triumph 11
K BN4 Locking Door Handle Removal Suggestions Austin Healey 10
catfood Looking for suggestions - ignition issue Austin Healey 6
55modified Need suggestions for fastening aftermarket hardtop for BN1. Austin Healey 15
Bob_Spidell Rebuild Performance Suggestions Sought Austin Healey 8
vette Any Suggestions As to Where to Buy a New BJ7 Gasoline Tank? Austin Healey 24
RAC68 Gear Reduction Starter Infor and Suggestions Requested Austin Healey 11
PatGalvin TR2/3/3A Vacuum Hose Fitting Install, Any Suggestions? Triumph 6
I General TR Mold clean up suggestions Triumph 4
Got_All_4 TR2/3/3A Suggestions for shoulder harness retractable/inertia seat belts Triumph 4
M suggestions on vendor Rear brake rebuild Spridgets 15
DerekJ Healey Blue Paint - suggestions Austin Healey 23
J General TR D Type overdrive not working need suggestions Triumph 5
2billydavies TR2/3/3A looking for suggestions on putting engine back in Triumph 17
G TR4/4A Yet another engine build thread. Parts list: Suggestions/Recommendations/Etc Triumph 11
dcoplan Suggestions for painting letters on dash knobs? Spridgets 6
I TR6 suggestions for brake LED bulbs Triumph 13
dcoplan Tires rubbing on frame - suggestions? Spridgets 2
I TR6 Muffler suggestions? Triumph 6
HealeyDave Car transport company suggestions needed - winter/midwest/USA Austin Healey 2
M Overdrive parts source suggestions Austin Healey 4
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
S TR6 Removing TR6 dash [and suggestions on refinish] Triumph 12
N Spitfire Spitfire sheetmetal prep and sealing suggestions wanted Triumph 2
Zimmycobra Trans problem. Looking for suggestions. Triumph 10
S Any suggestions on where to start? MG 7
D TR2/3/3A Suggestions needed for TR3 pricing Triumph 10
M TR4/4A 67 TR4A hasn't run for 10 yrs+... suggestions? Triumph 11
TRMark Brake pad suggestions Triumph 16
I Suggestions for bugeye headlights Spridgets 21
M suggestions for brake system Spridgets 9
RAC68 Paint & Design Suggestions Triumph 4
Andrew Mace lacquer primer removal suggestions Triumph 4
I LED tail light suggestions? Spridgets 22
G TR6 Radio suggestions for fitting to TR6 Triumph 3
hondo402000 suggestions on Ignition coils Triumph 22
I Suggestions for tach gear rebuild? Spridgets 8
J rear brake rubbing, need suggestions Triumph 12
BugeyeNJ58 Need new ignition switch..Suggestions? Spridgets 3
I Adhesive suggestions? Spridgets 4
I Wax, rubbing compound suggestions Spridgets 10
AngliaGT Subaru Wagon Suggestions? Other Cars 8
I Suggestions for new Bugeye soft top? Spridgets 3
TomMull carburetors not pretty, cleaning suggestions neede Triumph 13
RAC68 Suggestions – LED Project Austin Healey 24
O Suggestions.. Austin Healey 8
tmc Battery suggestions Triumph 5
