TR6 Rear Transmission Seal 74 TR6
EWD
Evening folks -
Just read the previous posts re: this topic and need some advice:
My interior is out, transmission and driveshaft tunnel covers off, and the 4 bolts connecting to the drive shaft are out.
Is the next step to take out the two large bolts securing the transmission (at base below shifter assembly)?
If so, I assume the unjoint separates.
Can you then jack up the transmission to allow access?
Just want to be sure of procedure before proceeding ( and before I break something......)
Andy and John - if you all are on line - this is the same project we discussed several weeks ago. Having some problems.
Thanks,
Will
Dr.T
Are you trying to replace the rear transmission oil seal with the transmission in the car? Is that even possible? Maybe it is, but I’ve always just pulled the transmission entirely out, then you can inspect a lot of other things.
CJD
Hey Will,
If the 4 drive shaft bolts are out, you should be able to pry the U joint to the rear and separate it from the yoke. Then push the drive shaft rearward out of your way. At that point it depends on the access you have to the rear of the yoke. I am not familiar with the tunnel cover on the TR6. If you can get a socket on the big nut holding the Yoke to the tailshaft, then you can work without disturbing the tranny mount. If you cannot, then you may have to undo the tranny mount to jack the end up enough to get the socket onto the yoke nut.
Once you get the socket on the nut, then put the transmission in 1st for the most leverage against the engine drag. You should then be able to remove the nut. It will likely take a breaker bar, and possibly a length of cheater pipe. If the engine turns before the nut, then put a wrench on the front of the engine and lean it against the frame or floor to hold the engine from turning. Once the nut is off, then you can tap off the yoke with a brass or wood mallet. Put the tranny in neutral and spin the yoke as you tap rearward. Some come off without even tapping...others take more work.
Once the yoke is off, you have to find a flat blade screw driver that can be used to carefully pry out the seal, without damaging the shaft seal surface. They make a hook shaped pry bar special for this...or worst case you can fashion one from an old screw driver...make it so it can fit in the crack and snag the seal. Then work it by prying one side and the other until you get it out. Take your time so as not to scratch the shaft...that would be bad!
Removing the old seal should be the hardest part of the whole job. Once it's out, just install the new seal and put everything back together. Best of luck!
EWD
EWD
Thanks John. I didn’t realize there would be enough play to push the shaft backwards. Trans presently in neutral and, for some reason, I cannot shift the gears. Worked previously (several months ago), But have lost a lot of oil. Car is presently on jacks.
CJD
The drive shaft may be stiff, but should move for you. Also remember to tape the U-joint so the caps will not fall off and spill needle bearings everywhere.
The tranny should be able to shift. If you turn the yoke while trying to shift, it will help to line up the gears to allow them to engage easier.
R J-H rear transmission seal? Why can't I find it on the web? Other British Cars 1
Bob Claffie MGB Transmission rear seal MG 8
2wrench TR6 Replacing rear seal on W58 HVDA transmission conversion. Triumph 4
Zitch TR4/4A Non OD rear transmission seal replacement Triumph 1
JPSmit Rear - Transmission seal question Spridgets 8
R_Lyle TR6 TR6 Transmission rear seal removal Triumph 4
T Looking for "BillMs rear transmission mount" Spridgets 2
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
R TR2/3/3A Lube for steering box, transmission and rear end Triumph 6
B Transmission rear bush for drive shaft yoke - no joke! Spridgets 2
R transmission and rear end oil Austin Healey 2
J TR 4 Rear Transmission Counterweight Triumph 8
Bruce_B %#@#%@ 5 speed transmission - rear mount!!--Help Spridgets 11
ronzet MGA MGA rear transmission mount MG 12
cdsmith Transmission oil? Rear end oil? Spridgets 15
C Speedo calibration vs rear end or transmission Austin Healey 13
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
B Rear Brake Cylinders Austin Healey 4
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
jfarris For Sale TR3 Rear Sway Bar Triumph Classifieds 0
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
