EWD
Evening folks -
Just read the previous posts re: this topic and need some advice:
My interior is out, transmission and driveshaft tunnel covers off, and the 4 bolts connecting to the drive shaft are out.
Is the next step to take out the two large bolts securing the transmission (at base below shifter assembly)?
If so, I assume the unjoint separates.
Can you then jack up the transmission to allow access?
Just want to be sure of procedure before proceeding ( and before I break something......)
Andy and John - if you all are on line - this is the same project we discussed several weeks ago. Having some problems.
Thanks,
Will
Thanks,
Will
