TR4/4A Master Cylinder Corrosion Do I replace?
rnpennington
I have this corrosion on my Master Cylinder, yet nothing on the Clutch Master cylinder. A few questions:
1) First and Foremost How and why did I get it?
2) Can I just clean the cylinder or should I replace it?
Attached are pictures
Inquiring Minds want to know.
CJD
It looks like the cap for that reservoir leaks a bit...are you using DOT3 fluid? If so, that is the culprit. DOT3 and 4 are hygroscopic, so once it spills it attracts moisture, and between the 2 it will cause corrosion. Since it is entirely external, so long as the cylinder operates fine I would just use a wire brush and/or toothbrush to remove the waxy scale and coat with a corrosion preventer, like LPS3 or other light oil. Of course, be sure to either tighten the cap more or replace the leaky cap seal.
charleyf
I have found that some of the caps on the newer TR4 M/C's do not seat correctly. The ones that I was dealing with had a cap thread that did not seem to fit the M/C thread. Even with a new seal i still had problems. I had several old caps and one other new cap and finally found one that fit tight. I know that this does not sound helpful. But I say it to give you something to look at. There is a lot of sloshing around of the brake fluid inside the M/C in normal driving. Or at least my kind of "normal driving".
Sarastro
Charley, I think that's true. Recently I had to replace my original clutch MC with a new reproduction one. The old cap, which I wanted to use, almost fit the new MC, but not quite. As I remember, the thread pitch was a little different and the thread depth was shallower. So, I stuck with the new one's plastic (ugh!) cap.
Merlin63Tr4
More worrying, than the external scale and waxy coating on the body of the brake master cylinder, is the visible corrosion on the master cylinder brake line visible in your pictures.
M
L Removing Master Cylinder Without Paint Damage Austin Healey 27
6 Master Cylinder Rebuild Spridgets 6
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
bighealeysource Master Cylinder Installation Austin Healey 9
bighealeysource BN2 Master Cylinder Austin Healey 91
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
bighealeysource Brake Master Cylinder Austin Healey 27
A Brake Master Cylinder Freeplay Austin Healey 11
SNClocks Master Cylinder Bore Diameter Spridgets 0
W replace rigid master cylinder lines with flex. Spridgets 2
6 Master Cylinder Actuator rods Spridgets 2
6 Master Cylinder Install Spridgets 5
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
R TR2/3/3A Master Cylinder Re-build Triumph 6
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
D TR2/3/3A sealing master cylinder pocket Triumph 8
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
R TR2/3/3A 1961 TR3A Master Cylinder[s] Rebuild Kits Triumph 4
R TR2/3/3A Lockeed Master Cylinder Adapters Triumph 8
D TR2/3/3A master cylinder res plumbing and unknown spacer Triumph 6
D Clutch Master Cylinder Leak Austin Healey 20
6 Master Cylinder Rebuild Help Please Spridgets 3
D BJ8 brake master cylinder question Austin Healey 6
Lin Master cylinder packing pieces [shims] Austin Healey 29
angelfj1 Wanted '59 TR3A Clutch Master Cylinder - USED, RE-BUILDABLE, NOS Triumph Classifieds 4
angelfj1 TR2/3/3A 59 TR3A Clutch Master Cylinder Failure Triumph 19
F Austin Healey Sprite MK I - master cylinder cap Austin Healey 1
D TR2/3/3A Brake Master Cylinder. Triumph 4
D 1965 Alpine Clutch Master Cylinder Sunbeam (Rootes) 0
Michael Oritt Brake Master Cylinder access Austin Healey 0
warwick-steve Final fix for clutch pipe to master cylinder leak?? Austin Healey 13
KVH TR4/4A Clutch Master Cylinder Triumph 3
warwick-steve Clutch master cylinder to fluid reservoir leak Austin Healey 5
R 3/4" Bore or 7/8" Bore Master Cylinder For Disc Brakes? Spridgets 4
bugedd Master Cylinder Question Spridgets 7
S Smitty trans Master cylinder Austin Healey 21
Rob Glasgow Clutch Master Cylinder Issue Austin Healey 3
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
nevets Master Cylinder question Austin Healey 8
JimLaney Sprite MK III combined master cylinder issue Spridgets 10
Got_All_4 TR2/3/3A Clutch issue maybe master cylinder Triumph 13
S MGB MGB clutch master cylinder MG 0
