Results 1 to 15 of 15
Thread: Side-Change Gearbox Stuck in Top Gear
  1. #1
    Join Date
    Apr 2019
    Location
    Wellington, New Zealand
    Posts
    5
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    I was out in my BN7 on Saturday and I had to stop at traffic lights. When I went to shift the gear lever into neutral, it wouldn't move and the gearbox has remained stuck fast in top. There were no nasty noises or any signs of trouble before and up to then the gear box shifted perfectly.
    I was able to continue home in top gear without any difficulty.
    Does anybody have any idea what is the cause and how I can fix it.
    I would be grateful for any advice.
    Crusty
  2. #2
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    4,159
    Thanks Thanks Given
    5
    57
    Thanked in
    Re: side change gear box stuck in top gear
    Was the box recently rebuilt? There are three (I think) spring-loaded balls and springs that go into the dog(?) gear to hold gears, if one or more is somehow jammed that would cause the problem. I assume you've tried to 'pop' it out with as much force as you felt comfortable with; too much and you could break a shift fork. If you're not able to pop it out I think you have no choice but to remove the side cover and have a look (I think you can do that in situ, no?).
  3. #3
    Join Date
    Apr 2019
    Location
    Posts
    5
    Thanks Thanks Given
    Thanked in
    Hello Bob,
    The gear lever is stuck fast. I have used a fair bit of force but I have been afraid if I use too much I might make the problem worse. It was suggested that I rock the car back and forth and this might free it up , but no success there either.
    I am not sure what to do now. I could take the side cover off, and you are right , it can be done in situ. My worry here is that I wouldn't have a clue what I am looking for or even at. If something has fallen off or out, where has it gone to. I think I will do as you suggest and see if I can find someone who knows about these old things to make a home visit.
    I am dreading removing the gear box from the car though.
    Thank you for your advice You have given me a starting point.
  4. #4
    Jedi Knight Keith_M's Avatar
    Join Date
    Aug 2012
    Location
    Logan, UT
    Posts
    979
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Re: Side-Change Gearbox Stuck in Top Gear
    Having just rebuilt my sideshift, I can offer a little help. Bob is right that the problem could be with the detente balls that engage the shafts holding the forks. There are three balls that are spring loaded on the side of shafts, one for each shaft. You will see these three balls and their springs when you remove the side cover. There are also two balls between the shafts, one above the center shaft and one below. Those two balls prevent you from moving one shaft while another shaft is in the "engaged" position. It's possible that one of those balls has gotten jammed somehow so that you can't move the 3rd and 4th gear selector fork shaft. You should be able to access the three spring loaded balls by removing the side cover, but I think you will have to remove the whole tranny to get at the two balls between the shafts because you have to remove the forks and shafts to get to them.
    If the problem is not those detente balls, then it could be something more serious with the 3rd and 4th gear shaft or the sliding hub that selects one of those two gears.
    Good luck,
    Keith
    Keith
    '59 Bugeye (recently restored)
    '62 BT7 (recently restored)
    '65 Sprite (restored 30 yrs ago)
  5. #5
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    4,159
    Thanks Thanks Given
    5
    57
    Thanked in
    I think the first thing to try would be to drain the oil into a clean pan and see if any metal comes out. You will have to do that to remove the side cover anyway, and if chunks of metal come out you'll know you have to pull the gearbox no matter what.
  6. #6
    Join Date
    Apr 2019
    Location
    Posts
    5
    Thanks Thanks Given
    Thanked in
    Thank you both for your comments. I will see how I get on this weekend and report back.
    I expect most of the Forum is thinking Thank God it's not me!!!!
  7. #7
    Jedi Knight TimK's Avatar
    Join Date
    May 2008
    Location
    Michigan
    Posts
    1,047
    Thanks Thanks Given
    6
    Thanked in
    http://www.britishcarforum.com/bcf/s...al-Replacement,
    @Crusty, I posted this guide to removing my side-shift transmission. If you decide to do it, it can be done, I did it 3 times.
    Tim K.
    1960 3000 BN7 (owned since 1981)
    1973 Yamaha TX500 (Owned since new -- 11,000 lifetime miles)
    Former LBCís: 1961 TR3, 1966 MGB (SCCA race car)
    First car: Volvo 122S
  8. #8
    Join Date
    Aug 2016
    Location
    Greensburg, PA
    Posts
    137
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Quote Originally Posted by Crusty View Post
    So how did you make out? My bet is that something happened at the synchro hub, preventing the engagement sleeve from returning to neutral.
  9. #9
    Yoda Randy Forbes's Avatar
    Join Date
    Feb 2003
    Location
    SW Florida (Sarasota/Bradenton area)
    Posts
    4,520
    Thanks Thanks Given
    12
    39
    Thanked in
    Quote Originally Posted by Bob_Spidell View Post
    DING! DING! DING!
    That's where my money says the problem is (from the guy that drove from just south of Atlanta to just north of Tampa, using only 4th & 4th/ovd).
    If that is (was) the case, then the xmsn has to come out and be disassembled to rectify.
    The cause__again, if that turns out to be the issue__is that too much clearance existed between the 3rd-4th synchro hub and the 3rd (constant mesh) gear. This allowed the inner hub portion to slide too far rearward as the engagement collar traveled too far forward, releasing the spring-loaded balls. It is the spring(s) sticking up that prevented the collar from being returned to its neutral or 3rd-gear position.
    With only three (3) posts, it is unlikely that we'll ever find out
    http://www.britishcarforum.com/bcf/image.php
    57 Healey BN6L-942 Wine Red/Honey Tan
    99 BMW M Coupe EB w/ ES/TS & 99 M Rdstr BK/BK
    01 BMW M Rdstr Steel Gray Performance Center (factory) Delivery
    16 X5M/DINAN Stg II Mineral White Metallic Wife's 716 hp/702 Lb-ft Turbo Hauler
  10. #10
    Join Date
    Aug 2016
    Location
    Greensburg, PA
    Posts
    137
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Quote Originally Posted by Randy Forbes View Post
    DING! DING! DING!
    Yeah, was rebuilding my box and that happened to me, fortunately while it was still on the bench. Without the bell housing attached the input shaft pushed out far enough that the balls came out too far. Bad enough I had to take it all apart again, but glad it wasn't in the car.
  11. #11
    Join Date
    Apr 2019
    Location
    Posts
    5
    Thanks Thanks Given
    Thanked in
    I haven't been able to anything about yet. I was away for a few days in mid March in Melbourne for the ( cancelled) F1 meeting. I had to go into self isolation because of the coronavirus for two weeks when I came back. Now we are in lockdown for at least four weeks which is more self isolation. I dont think I can do this on my own and while the lockdown continues, access to any assistance from friends is not possible.
    Crusty
  12. #12
    Yoda John Turney's Avatar
    Join Date
    May 2002
    Location
    Concord, CA
    Posts
    3,831
    Thanks Thanks Given
    58
    35
    Thanked in
    .... I dont think I can do this on my own and while the lockdown continues, access to any assistance from friends is not possible.
    Crusty
    Same situation here.
    John, BN4
  13. #13
    Join Date
    Apr 2019
    Location
    Posts
    5
    Thanks Thanks Given
    Thanked in
    The gearbox behaved faultlessly with no indication of any trouble or nasty grinding sounds coming from the gearbox. Just a stubborn refusal to shift out of 4Th gear.
    I am dreading to think where the ball (or balls) have gone to and if they have damaged any of the gears.
    crusty
  14. #14
    Join Date
    Jan 2011
    Location
    stamford, CT
    Posts
    2,396
    Thanks Thanks Given
    24
    Thanked in
    FWIW, in my 60 years of experience fooling with cars, 9 out of 10 times it's something simple and stupid. That 10th time will cost ya.
  15. #15
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    4,159
    Thanks Thanks Given
    5
    57
    Thanked in
    Quote Originally Posted by pdplot View Post
    ... and 9 out of 10 times carburettor problems are electrical.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
