Bugeye 1275 temp probe placement.
Rut
I currently have my temp probe in the radiator and every now and then I get a little air pocket which causes the temp to read low. Any reason not to move it to the head?
Thanks, Rut
Jim_Gruber
Rut, Mine is in the head, no issue with Bugsy and AM Aluminum Radiator. I'm using Revotec Inline Controller in lower hose to turn electric fan On/Off. I had a 180 degree thermostat and just switched to a 160. Have not tried it yet but RevoTec kicks electric fan on at 190 and with a 180 thermostat in there I seem to be kicking the electric Fan on a lot. Mechanical 6 blades fan also in place. Hopefully this will eliminate to much cooling stuff going on at the same time.
Billm
Rut
Assuming that you have a 1275, be sure to have that adapter in the head for the probe. Do not put the probe directly into the head!!
Billm
Jim_Gruber
Bill I just measured my old Jaeger Gauge and it is about 1 7/16 from the back of the collar to the end of the sensor. My new Smith gauge measures between 1.5” to 1 9/16 from the back of the collar. 1/8” deeper. So where do i find the adapter. Glad I learned this before I wrecked my new combo gauge.
Rut
Rut
Thanks for the info and I have an extra adapter for the temp probe. I currently have an electronic temp probe in the head just to plug the hole.
Rut
Jim_Gruber
So do I need to order 1 copper washer for the adapter and 1 for the probe? Thanks Bill M.
Jim_Gruber
Thanks Bill. Ordering today. Bugsy's coming together. Radiator plumbed and installed back to the heater. Todays challenge is to put front tilt brackets back on the bonnet and see if I can find help to get it installed, then cut and buff paint on the bonnet. Exhaust reinstall, Wiring Harness, Gas Tank to follow and then Vroom, Vroom. Windshield, Wipers, Interior to follow. Driving soon
P Temp. Probe for 1275 with Bugeye Radiator? Spridgets 21
A Bugeye engine swap, 948 to 1275 Austin Healey 11
T matching 1275 to bugeye rad ?? Spridgets 12
pbraun Radiator for Bugeye with 1275 Spridgets 20
TulsaFred 1275 Ribcase transmission in Bugeye - Which slave and pipe? Spridgets 23
B Bugeye 1275 Conversion Spridgets 6
I Bugeye 1275 engine conversion questions Spridgets 3
T Bugeye 1275 conversion question - alternator? Spridgets 8
T 1275 donor for the Bugeye or stay with 1098? Spridgets 11
B Bugeye + 1275 + Tach Drive Spridgets 13
P 1275 & Carb. Linkage for Bugeye Spridgets 4
Ohiobugeye Radiator for 1275 in Bugeye Spridgets 16
Kurtis 1275 Oil Filter Change on a Bugeye... Spridgets 10
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
J Finally getting (re) started on the Bugeye Spridgets 27
drooartz Restoring Penny the Bugeye Spridgets 22
drooartz Bugeye jack points to remove rear axle Spridgets 18
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
