Hi guys - been dormant on the Bugeye for a while but do have a planning question for you.
When I drop in the 1275 should I convert over to a negative earth alternator based charging system? And if so, what will I need to replace such as the regulator etc? I might need to spring for a new harness anyway since the wiring was pretty hacked up anyway....
Thanks for the coaching!
