HS4 mixture adjustment help please
bugedd
I watched a few how-to videos on adjusting the mix on HS4's, but I have one question. How far do you raise the piston? In one video I saw he just rolls a flat head screwdriver over to raise it slightly to get the desired raise of 50rpm then settling back down. Is that all you raise the piston, about 1/4"? Obviously if its raised too much the car stumbles. And is there a small air filter that goes over the velocity stacks? I have large round K&N with backing plates but they are so big I can't get to the jet adjustments. Thanks for the help!
JPSmit
Yeah, of the top of my head, about 1/4 inch - just a bit
Keith_M
I think it's more like 1/16 of an inch. You're supposed to just barely move it.
Nelson
I have H4's on my car and I found that the best result comes from raising the piston just a tiny amount will do the trick. Anything more than that will not yield a good response. I fully agree with Keith.
SaxMan
You can also use a Gunson Colortune spark plug. I found it made a nice "crutch" until I got more experience fiddling with the mixture.
Joe Schlosser
I thought the pin on the side of the carb supposed to lift the piston the correct height
JPSmit
bugedd
bugedd
Great, thanks for the help everyone! Got it running close and took it around the block, amazing how smooth it runs with carbs that aren't pulling vacuum leaks from everywhere!
bugedd
bugedd
So I drove it around a bit, and double checked the piston thing....turns out I have the pins to push them up, never saw that before. Pushing them up a skosh, not quite a smidge, resulted in the idle staying flat. Thinking that was pretty close I went to Pep Boys to get parts for the Mazda. Car ran well other than just off idle when lightly accelerating it was a touch choppy, like it wasn't getting enough of something. I'm thinking a bit lean? does that sound about right?
Keith_M
What kind, and how much, oil do you have in the dashpots?
JPSmit
my first thought too - check the dashpot first and then check the colour of the spark plugs.
BTW I checked the manual and, you are correct, it is a skosh not a smidge.
bugedd
bugedd
The dashpot oil is the SU oil I got from the rebuilder of the carbs, Minimania. As for the amount, just enough to where it doesn't come out the hole when the piston is fully raised.
Keith_M
Hmmm.... If it were me, I'd try richening it up a flat or two and see what happens. I assume you've checked your dwell and timing?
bugedd
bugedd
Ya, ignition is looking pretty good. I'll tinker with that today and see what I can mess up :smile:
G Setting mixture on HS4 carbs MG 30
torque-drive MGB SU HS4 jet height adjustments MG 6
G Twin HS4 Su's leaking fuel Spridgets 18
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
H General Tech SU HS4 Carb Question Triumph 5
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
dklawson Hs4 Float Bowl Failure Spridgets 11
RichBall HS2 and HS4 measurment Spridgets 7
bigjones HS4 needle mystery MG 15
mikecyc72usa Spitfire Spitfire 1500, SU HS4 major issue Triumph 14
fogliner My HS4 plumbing solution MG 13
bigjones 1500 - HS4 - improvements Spridgets 3
S Looking for hs4 aud 135r carbs MG 10
G HS4 fixed needle or spring loaded? [which is best] Spridgets 15
G HS4 carb question Spridgets 10
Gundy HS4 plumbing Spridgets 6
bigjones HS4 - quick question MG 6
G Carb floats SU HS4 on triple carb AH BT7 Austin Healey 10
bigjones HS4 - 1500 - slight problem Spridgets 24
JPSmit Quick HS4 Question MG 2
bcbug Installing a HS4 on a 76 Midget Spridgets 12
bigjones Single HS4 on a 1500 Spridgets 25
dklawson Single HS4 Conversion Troubleshooting Triumph 6
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
JPSmit HS4 needle question MG 2
JPSmit SU HS4 question MG 3
dklawson Spitfire ZS Stromberg vs HS4 SU on 1300 Spitfire? Triumph 11
Atrus Carb velocity stacks - are these HS2 or HS4? Spridgets 2
H HS4 to HIF inlet manifold question MG 2
don62 SU HS4 head jets adjustment MG 12
T Spitfire Spitfire HS4 help Triumph 11
T HS4 and HIF4 inter-carb linkages the same? MG 10
T HS4 vs. HIF4 MG 15
Atrus 1275 intake manifolds [Weber, HS4, custom] Spridgets 6
Atrus [2] HS2 vs [1] HS4 Spridgets 10
budk1953 Need a Pic of HS4's Spridgets 8
KLUTZ Properly tuned HS4's.. are they all the same? MG 6
wkilleffer MGB HS4 carb question- 18GK engine, 1974 MGB [long] MG 6
RobSelina Air filter housing for HS4 [also need tuning help] Spridgets 21
mgblue79 1500 Midget HS4 conversion Spridgets 8
KLUTZ HS4 Spring count. MG 1
E HS4 SU carb inlet diameter? MG 15
Jay_Nickell SU HS4 Rehab MG 5
sultanoswing HS4 carb question MG 20
RobSelina anyone have .... [now HS4 linkage problem] Spridgets 5
RobSelina plumbing a single HS4 on the 1500 Spridgets 5
mylillooker SU HS4's "vs" Weber 32/36 Spridgets 5
P MGB Choke on SU-HS4 1971 MGB MG 4
A T-Series Switch HS2's for HS4's ??? MG 3
RobSelina Single SU HS4 swap on a 1500 Spridgets 2
