HS4 and HIF4 inter-carb linkages the same?
tdskip
Question question - are the HS4 and HIF4 inter-carb linkages the same? Specifically how the throttle and chokes are linked?
Thanks.
Nunyas
I doubt it. Given the float bowl is on the bottom of an HIF, and off to the side of an HS, I doubt the linkages are the same. They probably attach to the cables the same or close to the same though.
Bob Claffie
The HS4's have a slightly longer interconnecting shaft. Probably somewhere around 3/4 inch more. All the other clips, pins, clevices etc are the same. Bob
I made linkage pieces up before, the round stuff is nothing more than bar stock. You can make it work by shortening or using a new piece of bar stock if you need it to be longer, it, and moving things around a bit. Remember anytime you are are working with strange linkage pieces that are not part of the original carb assembly, you need side to side play in the linkage or it will bind the throttle shaft.
Platinum
5/16" stainless bar stock. Hap noted the most improtant thing: a bit of "slop tolerance" side-to-side so the shafts don't bind. They should tolerate 1/8"~3/16" movement with no problem.
Platinum
We want photos of your solution! /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
Platinum
mehheh. Now I've a coffee spotted keyboard.
T HS4 vs. HIF4 MG 15
torque-drive MGB SU HS4 jet height adjustments MG 6
G Twin HS4 Su's leaking fuel Spridgets 18
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
bugedd HS4 mixture adjustment help please Spridgets 13
H General Tech SU HS4 Carb Question Triumph 5
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
dklawson Hs4 Float Bowl Failure Spridgets 11
RichBall HS2 and HS4 measurment Spridgets 7
bigjones HS4 needle mystery MG 15
mikecyc72usa Spitfire Spitfire 1500, SU HS4 major issue Triumph 14
fogliner My HS4 plumbing solution MG 13
G Setting mixture on HS4 carbs MG 30
bigjones 1500 - HS4 - improvements Spridgets 3
S Looking for hs4 aud 135r carbs MG 10
G HS4 fixed needle or spring loaded? [which is best] Spridgets 15
G HS4 carb question Spridgets 10
Gundy HS4 plumbing Spridgets 6
bigjones HS4 - quick question MG 6
G Carb floats SU HS4 on triple carb AH BT7 Austin Healey 10
bigjones HS4 - 1500 - slight problem Spridgets 24
JPSmit Quick HS4 Question MG 2
bcbug Installing a HS4 on a 76 Midget Spridgets 12
bigjones Single HS4 on a 1500 Spridgets 25
dklawson Single HS4 Conversion Troubleshooting Triumph 6
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
JPSmit HS4 needle question MG 2
JPSmit SU HS4 question MG 3
dklawson Spitfire ZS Stromberg vs HS4 SU on 1300 Spitfire? Triumph 11
Atrus Carb velocity stacks - are these HS2 or HS4? Spridgets 2
H HS4 to HIF inlet manifold question MG 2
don62 SU HS4 head jets adjustment MG 12
T Spitfire Spitfire HS4 help Triumph 11
Atrus 1275 intake manifolds [Weber, HS4, custom] Spridgets 6
Atrus [2] HS2 vs [1] HS4 Spridgets 10
budk1953 Need a Pic of HS4's Spridgets 8
KLUTZ Properly tuned HS4's.. are they all the same? MG 6
wkilleffer MGB HS4 carb question- 18GK engine, 1974 MGB [long] MG 6
RobSelina Air filter housing for HS4 [also need tuning help] Spridgets 21
mgblue79 1500 Midget HS4 conversion Spridgets 8
KLUTZ HS4 Spring count. MG 1
E HS4 SU carb inlet diameter? MG 15
Jay_Nickell SU HS4 Rehab MG 5
sultanoswing HS4 carb question MG 20
RobSelina anyone have .... [now HS4 linkage problem] Spridgets 5
RobSelina plumbing a single HS4 on the 1500 Spridgets 5
mylillooker SU HS4's "vs" Weber 32/36 Spridgets 5
P MGB Choke on SU-HS4 1971 MGB MG 4
A T-Series Switch HS2's for HS4's ??? MG 3
RobSelina Single SU HS4 swap on a 1500 Spridgets 2
