Spitfire Spitfire 1500, SU HS4 major issue
mikecyc72usa
Ok, I've scoured the archives, and tried everything mentioned. The whole story:
A few days ago I took off my carbs (SU HS4) to clean them. I disassembled them, cleaned everything with carb cleaner, and reassembled them. Before the cleaning there was an intermittent miss above 4k rpm.
I put the carbs back on, and the car can barely hit 60mph on a level road. Before it had no problem cruising at 85mph. Took carbs apart, front carb throttle plate was a little off. Fixed that, which fixed idle problem. Yet still no power. Hit the gas and it just bogs down. Mixture makes no difference. Timing is spot on. Fuel going to both carbs. Pump and filter are good. Plugs are perfect color. Float levels are spot on. If I had another set of carbs I'd throw them on to see what would happen.
I've checked for vac leaks. There is a slight leak on each throttle shaft. Surpise there, I know. I have one more thing to check. I wonder if a jet tube somehow got kinked and the fuel flow isn't quite right. Thoughts?
TR3driver
Great Pumpkin - R.I.P
Have you checked that the throttle plates open all the way when you mash the loud pedal?
Tried doing a plug cut?
What about a fuel volume test, or actual pressure at WOT?
mikecyc72usa
mikecyc72usa
Plates work perfect. Plugs perfect. Not sure about the fuel volume. Just so weid that all I did was diasassemble and clean and this happened. I must have changed something that I'm missing without realizing it. Wait. I just realized that the spring loaded "valves" on the outside of each carb were stuck shut. These are the ones that if you push up on them the slide rises slightly. When cleaning they became unstcuk. I wonder if that could be causing a vac leak when I hit the accelerator.
dklawson
You say you have disassembled both HS4s to clean them. Were you careful not to mix components when you put the carbs back together. Each piston and vacuum chamber are matched to each other and during tuning the needle is centered in the jet. If you mix components between the carbs you can expect issues.
The "valve" you mention sounds like you are describing the lifting pin used during tuning. No appreciable amount of air leak will occur around them. However, if they stick, they may be holding a piston up... or indicate that the piston is sticking.
Were these my carbs I would go through them again from scratch. Center the jets, start with the basic "first start" settings. Once the engine is warmed up, balance the air flow and set the mixture.
If you think you have mixed the pistons and vacuum chambers between the carbs, go to YouTube and look up John Twist's videos on how to check the "drop rate" of the carb components so you arrive at the best mix of parts when you put the carbs back together.
tdskip
Sorry for asking, but we're sure it is not ignition?
It seems odd to me that the plugs would be showing good mixture with the behavior you are describing. (I mean this cooperatively of course).
mikecyc72usa
mikecyc72usa
No, I agree. I even reset the timing with the timing light, checked the advance, and used a colortune. At idle it's perfect. Could it be a needle isn't quite right after disassembly? I left the needles in the slide/piston to avoid that, but you never know. I'm really vexed. 30th Triumph of my life and I've never fought carbs this long.
Here would be really one of those "opps" questions, but you said you removed the carbs, did you remove the entire assembly, and disconnect the throttle cable, if so are you sure it is opening to full open, stranger things have happen, you can easily test this by having someone push the gas pedal to WOT position with the car not running and see if you can move the throttle linkage further by hand, if you can, then cable needs to be adjusted.
The other thing is to get all the air filter out of the way so you can actually see the piston motion in the carbs as the engine runs and make sure they are moving freely and not sticking.
As for your leaks at the sahft, HS4s are notorious for shaft leaks as the shaft wears and this can be redone duing a rebuild process with special machining tools.
mikecyc72usa
mikecyc72usa
I have the air filters off, and only took the carbs off the manifold, leaving all that in place. Even when I hand operate the throttle with the linkage between the carbs same thing. Instant response then tapers off almost immediately and almost total loss of power.
mikecyc72usa said:
It was very simple. Gasket from jet to float bowl on front carb was mangled and blocking fuel. Now time to reset all the other things I've done to make sure it's running properly. Thanks everyone!
Well goodfor you, if you're talking about the rubber gland that goes on the end of the jet fuel tube, make sure you get a new proper part, Joe Curto has them, www.joecurto.com, a regular o-ring if used will fail in short order.
mikecyc72usa
mikecyc72usa
Hap, I did have a proper spare. I am going to still get another set of carbs, put them on the car, then decide if I want to rebuild or just sell these. I may fully rebuild them just to have an extra set since I also have a 1971 MGB nearing completion. Talk about a maddening experience.
JKB1957
If you have a PCV valve on your intake manifold, and it has become dislodged, this can cause the symtoms you are having.
G Spitfire Spitfire 1500 differential whining Triumph 6
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
R Spitfire Spitfire 1500 Triumph 3
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
dklawson Spitfire Spitfire 1500 Block Decking Following Boring ??? Triumph 4
dklawson Spitfire Spitfire 1500 - Front Pulley Nut Removal? Triumph 2
F Spitfire Spitfire 1500 Mechanical Fuel Pump & Spacer Triumph 6
B Spitfire Advice on swapping to J Type OD with 1500 engine in 69 Spitfire Triumph 13
T Spitfire 1979 Triumph Spitfire 1500 Triumph 3
S Spitfire 1973 Spitfire 1500 Dashboard question about warning light Triumph 3
T Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment Triumph 4
F Spitfire Spitfire 1500 Dash Lights Triumph 1
W Spitfire Spitfire 1500 Steering Column Triumph 3
dklawson Spitfire Clutch Kit Preference - 1500 Spitfire Triumph 3
Anthony_S Spitfire Spitfire 1500 for sale in my area Triumph 1
S Spitfire Is a 1973 spitfire a 1500 or a mark IV? Triumph 7
dklawson Spitfire Spitfire MkIV/1500 - Factory Front Spoiler? Triumph 3
dklawson Spitfire Spitfire MkIV/1500 Body Gaps - Bonnet to Bumper Triumph 2
F Spitfire Spitfire 1500 Door Handle Removal Triumph 1
F Spitfire SUs On a Spitfire 1500 Triumph 14
Scott_Hower Spitfire Late Spitfire 1500 CV driveshaft Triumph 3
F Spitfire Spitfire 1500 - Stromberg CD 150 Question Triumph 9
F Spitfire 1500 Spitfire Windshield Glass, Gasket and Install Triumph 12
Don_R Spitfire Spitfire MKIV/1500 parts book Triumph 2
F Spitfire Spitfire 1500 Electrical Question?????? Triumph 4
F Spitfire 77 Spitfire 1500 Questions Triumph 3
mikecyc72usa Spitfire First Autocross in my Spitfire 1500 Triumph 29
F Spitfire 1500 Spitfire Engine Noise Triumph 14
A Spitfire TRIUMPH SPITFIRE MKIV 1500 Triumph 2
K Spitfire 60’s spitfire body swapped onto a 1500 cassis Triumph 3
M Spitfire Spitfire 1500 OD transmission Triumph 9
A Spitfire Triumph Spitfire 1500 Triumph 8
K Spitfire Spitfire Mk IV tonneau =Spitfire 1500 tonneau? Triumph 2
dklawson Spitfire Crank Endfloat and Oil Pumps - Spitfire 1500 Triumph 9
bowiderberg Spitfire Whitworth on a Spitfire 1500? Triumph 8
This14u Spitfire 1500 Spitfire Header Recommendation Triumph 0
pjsmetana Spitfire Spitfire 1500 TC Triumph 2
frankenstang57 Spitfire Spitfire 1500 fast road cam question Triumph 4
1965_MGB Spitfire Junkyard Find, Spitfire 1500 I think Triumph 6
JodyFKerr Spitfire 1978 Spitfire 1500 Triumph 32
roofman Spitfire Anti run on valve ? spitfire 1500 Triumph 3
c5racer Fit an exhaust manifold from a 1500 Spitfire? Spridgets 2
