Tunebug exhaust question
drooartz
Okay -- I started playing with fitting the exhaust on the Tunebug today. I have a stainless system from APT that I bought when I bought the Maniflow header last winter. I'm not terribly pleased with it so far. It's set up to go over the back axle, but I'm not entirely sure it's the best solution. Seems it may hit my parking brake rods, and the muffler doesn't seem to line up properly with the mounting stud. (This is for a 1275 in a Bugeye.)
I'm not even quite sure how it all mounts. This is a larger pipe, so I'll need new hangers. My questions are these:
1. How does the pipe mount towards the front of the car?
2. Should I just take the car to a muffler shop and have them make me a pipe to fit.
3. If yes to #2, what do I use for a muffler?
4. Is there something else I am missing here? I'm quite ready to believe operator error here. :smile:
smaceng
Hi,
Not sure what version you have of the exhaust, but the stock version goes UNDER the rear axle. I would ask your vendor, David, if you have the correct item.
Scott in CA
Billm
If it's from APT I would trust it enough to at least try it as is- they have a pretty good rep.
BillM
MCS
Hello,
I used an RC40 muffler off of a classic mini. The guys at swiftune in the UK say it is a good compromise between performance and noise. I used a straight pipe under the axle. The problem I have is every time I lift the car the axle sits on the pipe and pulls it down. In the spring I am going to go over the axle like you have. I have two hangars only, one on the back wall where the electric fuel pump mounts and a hangar holding the muffler output pipe, hanging off of the rear of the trunk. The clamp I used off of my 2 inch APT maniflow header is a std u shape clamp. I hate it, it gets in the way, I have been told there is some other kind of clamp that takes less room, will change that to. I am really busy today; otherwise I would post a picture. Maybe tonight if you need one.
Phil
tdskip
Drew - if you haven't had a chance to call them yet give them a ring on Monday. I'm lucky in that these guys are somewhat local so I've gotten to know them a bit, and as other have said, they are really focused on doing the right thing and honestly care about their customers. Not every part or vendor is going to be perfect, but these guys are about as close as I've seen.
My guess is that you are going to need to change the way the exhaust is located to give yourself clearance - you've probably started to sort that out already but maybe changing the height or location of the rear most hanger???
GB1
Phil
Nice to see someone else running a RC40, I have had mine for 15 years and am very happy with it.
Pat
drooartz
drooartz
I did talk with David from APT after I received this, and this is how they're doing the exhaust now. I just need to get back in there and get everything lined up. I was just a bit frustrated yesterday. :smile:
Sounds like I'll be okay with the one hanger at the rear (just forward of the axle) and the hanger for the muffler.
drooartz Tunebug exhaust Latest Spridgets 6
AN5Sprite Some Seasonal Tunebug Pics Spridgets 24
AN5Sprite Tunebug comes to life Spridgets 10
Hap Waldrop Tunebug' head repaired and on it way back to Steve Spridgets 23
AN5Sprite Tunebug engine diagnosis, thoughts anyone? Spridgets 47
AN5Sprite Tunebug is all alone now. Spridgets 3
AN5Sprite Tunebug landed... Spridgets 6
AN5Sprite Tunebug in transit Spridgets 1
AN5Sprite Tunebug's new house Spridgets 30
drooartz Tunebug is ready to go Spridgets 2
drooartz Packing the Tunebug Spridgets 4
drooartz Bittersweet day: Tunebug has sold Spridgets 19
drooartz It's true: the Tunebug needs a new home Spridgets 27
drooartz Back at it -- Tunebug is in pieces Spridgets 9
drooartz Tunebug vs MGB, initial thoughts Spridgets 67
drooartz Got the Tunebug out today Spridgets 8
drooartz Tunebug's temporary new home Spridgets 26
drooartz Tunebug's first drive of 2011 Spridgets 15
drooartz The Tunebug is ready! Spridgets 11
drooartz Tunebug goes to the doctor Spridgets 16
drooartz Tunebug is going to the doctor Spridgets 4
drooartz Tunebug goes to work Spridgets 18
drooartz Tunebug tailpipe Spridgets 3
drooartz My new favorite Tunebug pic Spridgets 10
drooartz Actual work done on the Tunebug! Spridgets 8
drooartz Tunebug progress: radiator in! Spridgets 16
drooartz Tunebug progress this weekend Spridgets 7
drooartz Tunebug hiatus Spridgets 12
drooartz The weekly Tunebug Latest: painting bits Spridgets 4
drooartz Tunebug has a new friend Spridgets 15
drooartz What Tunebug should be when done Spridgets 10
drooartz Tunebug turns 48 Spridgets 7
drooartz Tunebug's off the road for a while Spridgets 1
drooartz Tuning the Tunebug, now with video Spridgets 14
drooartz A bit of Tunebug progress Spridgets 10
drooartz The new, improved Tunebug 2007 plan Spridgets 6
drooartz Tunebug plans, written down Spridgets 16
drooartz Found a bit more knee room in the Tunebug Spridgets 4
drooartz The Tunebug Valdeze pictures Spridgets 2
J TR4/4A Exhaust a tad too loud... Triumph 6
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
CARSINC Please Identify this Exhaust Header Spridgets 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
TomMull GT6 "Sports" Exhaust Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
