TR2/3/3A TR3 Oil Breather Mounting
RedTR3
Can someone please share the correct mounting for the TR3 oil breather tube...There is a bracket on the lower portion and I am not sure where the bracket connects to. Thanks!
sp53
There should be a little piece between the breather and the oil pan. One side goes to an oil pan bolt and the other goes to the breather. There were variants on the little connecting piece. Some are twisted and some are flat.
Steve
RedTR3
RedTR3
Thanks! I have another question now...How far into the block hole should the breater pipe go? Mine just barely fits the outside of the hole and really does not fit inside.
Darrell_Walker
I believe it should go quite far in. Mine (not installed yet) has a dimple about an inch and a half down, which I assumed is a stop.
TR3driver
Great Pumpkin - R.I.P
Mine goes in quite a bit too, 1-1/2" or so. I've not seen a dimple though, so perhaps that was a later change (like the flat link instead of twisted).
Could you have a broken stub in the hole? Or the wrong tube?
RedTR3
RedTR3
This is the same tube that has been on the car for a long time, and it's not broken off. But the oil pan was off recently when my mechanic had to remove a piston (Long story).
Perhaps in the jostling around the tube was dinged or bent out-of-round...I'll take it out and inspect.
Don Elliott
There is a round washer (spacer) that has to be used for the bolt on that corner of the oil pan that also secures the sump vent pipe. The spacer is needed because of the rim which turns down on the outer flange on the oil pan.
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
S TR2/3/3A What weight transmission oil in a tr3 with OD? Triumph 13
M TR2/3/3A Crosland Oil Filter Pn for TR3 Triumph 2
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
B TR2/3/3A normal oil pressure in TR3 Triumph 6
S TR2/3/3A TR3 Gearbox Dipstick Question on oil level Triumph 18
jfarris TR2/3/3A TR3 Oil Filter Canister Removal - YUK Triumph 6
T TR2/3/3A TR3 Oil Pan Paint? Triumph 2
M TR2/3/3A TR2 TR3 oil cap decal Triumph 18
K TR2/3/3A Castrol 20/50 Motorcycle Oil for TR3? Triumph 2
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
Scotsman TR2/3/3A How to Mounting Oil Cooler on TR3 Triumph 3
toysrrus TR2/3/3A What Oil goes in your TR3/4 Trans? Triumph 14
G TR2/3/3A TR3 Oil Strainer Repair Triumph 6
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
B TR2/3/3A oil pump drive shaft removal challenge on TR3 Triumph 14
AHS TR2/3/3A Which way does the TR3 front crankshaft oil seal face? Triumph 8
K TR2/3/3A TR3 dipstick marks and oil level? Triumph 5
P TR2/3/3A TR3 Transmission oil Triumph 13
M TR2/3/3A TR3 oil filter cap needed Triumph 8
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
J TR2/3/3A TR3 oil pressure hose question Triumph 1
R TR2/3/3A TR3 oil pressure relief valve Triumph 4
luke44 TR2/3/3A TR3 Oil Gauge Line Triumph 3
K TR2/3/3A TR3 Oil Pressure Timing Chain Tensioner? Triumph 0
B TR2/3/3A No oil to rockers on rebuilt TR3 Triumph 10
Geo Hahn TR2/3/3A TR3/4 Oil Pan Gasket Triumph 49
mgedit TR2/3/3A TR3 Spin-on Oil Filter Triumph 7
toysrrus TR2/3/3A TR3 Gear Oil Recommendations Needed Triumph 6
K TR2/3/3A Anyone running an Oil Temp sensor on their TR3/4? Triumph 11
K TR2/3/3A What was best Spin Oil Filter for TR3 & 4 Engines? Triumph 9
K TR3 Oil Temperature readings Racing 2
M TR2/3/3A TR3 aluminum oil pan Triumph 9
K TR2/3/3A TR3: diff oil on the rear brake shoes... Triumph 4
TomMull TR2/3/3A TR3 oil gallery plugs Triumph 2
PatGalvin TR2/3/3A Target Oil Pressure for new TR3 Rebuild? Triumph 4
mountainman TR2/3/3A TR3 Oil Pan Gasket? Triumph 7
S TR2/3/3A tr3 tranys oil Triumph 10
mountainman TR2/3/3A TR3 Leaking oil pan Triumph 17
TR3TR6 TR2/3/3A TR3 rear oil seal Triumph 2
S TR2/3/3A tr3 Shock oil leaking Triumph 2
J TR2/3/3A TR3 Oil Galley Plug, HELP!! Triumph 4
toysrrus TR2/3/3A Re: TR3 "Front" Main Oil Seal: Triumph 3
S TR2/3/3A little brackets for oil line tr3 Triumph 3
RedTR3 TR2/3/3A TR3 Oil Pressure Gauge Hose Triumph 3
newmexTR3 TR2/3/3A Oil pressure running high - TR3 Triumph 6
CraigLandrum TR2/3/3A TR3 Low oil pressure [again!] Triumph 23
newmexTR3 TR2/3/3A TR3 Oil Pan thread repair Triumph 6
CraigLandrum TR2/3/3A TR3 Oil pressure normal? Triumph 26
