TR2/3/3A Target Oil Pressure for new TR3 Rebuild?
PatGalvin
Hey Guys
What should my oil pressure be at idle when I start my newly rebuilt engine?
I've been stressing over this rear seal oil leak and a very smart buddy of mine thought my oil pressure at 70 psi (idle) was too high and this could be blowing by the seal. I disassembled the oil filter head so I'm sure I disrupted the factory oil pressure settings.
Pat
TR3driver
Great Pumpkin - R.I.P
70 psi is fine. The rear seal is not exposed to oil pressure, so oil pressure has relatively little effect on it.
Some claim that the drain hole for the space between the rear main & seal is too small, and so too much _flow_ might cause pressure to build against the seal. But if you are carrying 70 psi at idle, there isn't too much flow.
If you really want to prove the point, try changing to 5W30 oil. Most likely, it will lower your idle oil pressure, and increase the leak.
PatGalvin
PatGalvin
Thanks Randall
I did drill the rear main cap to allow better drainage, per directions for new seal. Thanks for insight on this.
Pat
MDCanaday
The real fun starts when you put a fresh set of bearings into a motor that has had the relief screw over adjusted.When you start it up, the pressure blows the gauge to hades in a spray of hot oil!!!You will only do this once in your life....
MD(mad dog)
longbridgehealey guess I'm gonna paint a target on my 100-6 Austin Healey 14
Basil Target Date Jaguar 3
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
Celtic 77 MGB 77 MG B oil cooler MG 5
KVH General Tech Oil Pump Woodruff Key Triumph 10
prb51 Oil Viscosity Austin Healey 10
A MGB Oil pressure MG 9
NutmegCT Oil comparisons Restoration & Tools 2
Gliderman8 TR6 Would you change oil? Triumph 5
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
