TR2/3/3A No oil to rockers on rebuilt TR3
Bruce100
I bought a TR3B rebuilt by previous owner, who quit work on it. I want to preprime it, as previous owner stated it wasn't getting oil to the rockers. I am thinking of using a dowel slotted to drive the pump with a drill motor to preprime, to verify that this is in fact the case. Anyone ever done this with a TR3B engine?
TR3driver
Great Pumpkin - R.I.P
It's the other way around, you need a shaft with a tang sticking out to engage the pump shaft. It also needs to fit the bore snugly as the shaft passes through the oil passage.
Haven't tried it myself, but I suspect that because of the way the rear cam bearing meters the oil to the rocker shaft, you might not get oil to the shaft even if there is nothing wrong. My suggestion would be to install the pump drive & distributor, then spin the engine with the starter (plugs out) long enough to build pressure on the gauge. You probably still won't see oil to the rockers at that point, but it will be safe to start the engine and let it idle for a minute or two, to see if that gets oil to the rockers. The flow to the rockers is deliberately quite slow, they basically see no pressure at all even with the engine running.
If not, unfortunately, the most common problem after a rebuild is that the rear cam bearing was installed back-to-front. The 3 holes are not evenly spaced so there is only one way it goes in, and it's easy to overlook the oil hole in the top.
BTW, Welcome to the Asylum :smile:
TR4nut
If you have a spare distributor drive, just remove the drive gear and use the shaft and slot it in the pump - and yes, you can drive that shaft with a drill and you will be able to pressure up the whole system. Just did that on my 3A and it works fine.
Also, if you are not firing it up you might consider pulling the rocker assembly and just see if you are getting oil to come up through the head - maybe thats overkill but it would provide easy verification.
I agree with Randall on that cam bearing - if its misoriented I think you are looking at a pulled engine to get at everything. Hopefully that is not the case - if you get to the point of pulling the cam you can at least check the holes with an inspection mirror. I also used a small allen wrench to see if the holes were open which is a pretty easy verification method.
B
Bruce100
Fortunately the tub is off, and I can get to the engine. I assume I don't have to pull it off the chassis frame as well.
TR4nut
No, you could leave it on the frame - but if you do find you need to pull the cam bearings you will need to pull the gearbox for sure. After the rear cam bearing there is the equivalent of a freeze plug which would need to be knocked out and that can't be accessed with the gearbox attached.
TR4nut
Here's a link to some pics I took when I installed those bearings. I'm sure there's other ways to do it, but it might give you some idea of what you'd be dealing with.
TR3/4 cam bearing install
TR3driver
AHA! So that's where my cam bearing mandrels went!
:devilgrin:
Seriously, good writeup Randy. As I recall you can also verify the hole position to some extent by holding a light in the bearing and looking down the drillings. Plus of course you have to check that the locating slot is centered in it's hole, so the locking pin doesn't catch on the bearing insert and damage it.
Got_All_4
I agree with Randy to pull the rocker shaft off. You can spin the engine and see if your getting oil from the block. If not then you know where the problem is. One cushion is the cam followers. With no presser on the followers they could stick on the way down and the cam lobe will hit them on the next pass.
Could the pedestals be in the wrong order. The one with the hole in the bottom not lining up the hole in the head? Don't know if that's possible.
TR3driver
Which is just why I don't recommend that. There is a chance it will throw a lifter completely out of it's bore, and while it is usually possible to coax them back in without removing the head, it is certainly a PITA.
Also don't forget that it can take a long time for oil to fill the passage all the way to the top, especially at cranking speeds. I make it a point to check oil flow to the rockers after adjusting the valves, and it can take a minute or two of idling to get oil out of all the rockers.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]
Could the pedestals be in the wrong order. The one with the hole in the bottom not lining up the hole in the head? Don't know if that's possible. [/QUOTE]
Possible, I guess, if someone assembled the shaft wrong. The pedestal with the oil hole is also the one with the screw that locates the shaft to the pedestal. It should be the rearmost pedestal.
Tabcon Aux. oil feed line to rockers? Triumph 15
martx-5 No oil to the rockers!! Triumph 10
tahoe healey Stream of Oil from Rockers Austin Healey 8
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
Celtic 77 MGB 77 MG B oil cooler MG 5
KVH General Tech Oil Pump Woodruff Key Triumph 10
prb51 Oil Viscosity Austin Healey 10
A MGB Oil pressure MG 9
NutmegCT Oil comparisons Restoration & Tools 2
Gliderman8 TR6 Would you change oil? Triumph 5
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
