SU hs4 carbs
XJRpilot
just figured i'd ask if anyone has a tip for tuning the hs4 carb for winter. ever since the weather got real cold, the b is running like crap.
a little backfiring here and there, with the engine stalling sometimes from idle/acceleration. seems sluggish then all of a sudden will regain its power. i tried to do the mixture adjustment myself, but i kinda screwed up. i tried to turn them both the same amount, but got carried away.
(brain freeze) how do i reset them to start all over again? also on the idle adjusting nut on the bottom of the suction chamber(dashpot), is the adjustment right for rich and left for lean or vice versa?
what about dashpot oil? i'm using 20/50 castrol.
is it too heavy for this weather?
thanks guys and gals.
RHWins
Your dash pot oil is WAY too heavy. Try auto transmission fluid, it helps keep down the deposits on the valves. And don't overfill.
Lynn Kirkpatrick
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by XJRpilot:
<hr></blockquote>
If you haven't done it before, adjusting the SU's is too complicated to describe here. The directins may be in the forum someplace (Basil?), or go to Google.com and search on SU carbs. I bought the doodad that used to balance the carbs at idle & it works. It was worth the $'s.
ABOUT THE DASHPOT OIL: everything printed says 20w-50, which I have been running for the 3+ years with no fouling, should AT oil be used in the winter & 20w-50 in summer? Does it make a difference? Is AT OK all year?
Gary Lloyd
I would always say checkeverything else before your carbs!! There may have been a little water in the tank or anything!! First thing, add gasline antifreeze, second thing check points, timing and plugs!! Last thing carb settings!! GOOD LUCK BUDDY!!!
coldplugs
Lynn's right re the SU's - you need a fair amount of info. The best source to start with is a shop manual.
Re the SU damper oil - I spent a lot of time on this years ago (on a Jag) experimenting with different weights. I tried one, drove the car, sucked it out and tried another. I tried light machine oil through 40 weight and settled on 30 weight as the best (it wasn't winter, though). There wasn't much difference between them except for the very light oil. I think 20/50 is fine.
X
XJRpilot
i have the repair manual but the directions are somewhat confusing. looking for the laymens version. as for the carb air flow meter, i can use the hose in the ear method for now. i am planning to get one after the new year. what about marvel mystery oil? the 20/50 looks awful thick in the dashpots in this cold weather.
piman
Hello XJRpilot,
Mixture adjustment is very easy, screw the nut down for a richer mixture, this pulls down the jet. As a ball park starting point, remove both
dashpots and pistons\springs and screw the jets all the way up until they are flush with the bridge. Undo the adjusting nut twelve flats, that is two full turns down, you should now be near correct. (Also make sure your choke linkage is free and returns the jet full home).
(It doesn't matter what needle you have fitted, they all have the same idle dimension, it won't run well over the rest of the range if the needles' are wrong though.)
Check that your piston and dashpot are clean inside, and if not use a solvent cleaner to clean them. (DO NOT USE ANY SORT OF ABRASIVE, EVEN METAL POLISH). Also check that the needle is fitted with the shoulder flush with the piston lower face. Relace and carry out your balancing, (the tube method is quite acceptable), and idle speed adjustment.
S.U.'s are really quite easy to adjust as long as a couple of basics are correct, and in my experience do not go off tune quickly.
Alec
aeronca65t
I agree with Alec's explaination above for basic tuning of SUs (and he's right, they are pretty easy to deal with).
Gary's comment about checking *everything else* is also a good idea...at least check plugs (and points, if you have them).
If the car is slow to warm up (is it?), check thermostat....could be a *low* thermostat (160 F.), which will cause poor cold weather running.
Re: Marvel Mystery Oil. It's mostly kerosene (a light oil). I've been runing 10W-30 or 30 weight for years with success. I went to a carb forum at the AH Encounter event in Princeton this summer; the speaker said he swears by 3-in-One oil (which is like 5 weight oil and similar to Marvel Mystery Oil or even ATF). He got a lot of grief about this, but I think this might be OK for a car that has the carb dampers checked frequently. I'll probably continue with 10W-30, since it's always one hand.
X
XJRpilot
thanks alec and nial. i thought there should be a starting point for setting the jets. twelve flats = two full turns. its funny because my better half said a flat is probably the flat part of a bolt. not a complete turn. then she said if a bolt
has six sides than it has six flats. i was speechless. maybe i ought to have her tune my su's.
as for the 30wgt oil in the dashpots, sure it isnt too thick? its awful cold around here.
the oil looks like molasses in siberia. couldnt i go lighter for winter, than switch as the weather gets warm?
piman
Hello again XJR,
Sorry, forgot about the oil. The correct grade is S.A.E. 20, and in practice I used engine oil, 20\50 which works fine in our temperatures. I think in very cold weather a thinner oil will work fine. The oil is to dampen the (too) rapid rise of the piston when you open the throttle and stops the mixture going weak. Just play around until you feel that it runs well. Bear in mind that the underbonnet temperature will warm everything up.
One basic I did not mention, make sure the needles are centred in their jets. This should only need doing after a rebuild, but if the jet nut has been slackened by mistake your needle can bind on the jet preventing it from going to the idle position. Take the air cleaner off and lift the piston by hand and release, it should drop down with a click onto the bridge. If it does not, then (assuming the piston is free in the dashpot) screw the adjusting nut fully up, slacken the jet clamping nut, (directly above the adjusting nut) and push down on the piston to centre the jet. Tighten the clamp nut the back off the adjusting nut two full turns and readjust the mixture. It is harder to write about than do.
Alec
X
XJRpilot
alec,
you wrote:
>and in practice I used engine oil, 20\50 which >works fine in our temperatures.
in northern pennsylvania where i live, it has been
unseasonably cold lately. around 15-20 degrees F.
>Bear in mind that the underbonnet temperature >will warm everything up.
i did figure that the underbonnet temps would help, but after a hour drive, i put my hand on the dashpots to check, and they were ice cold.
maybe the car is just running cold. maybe thermostat change or perhaps i should partially cover the oil cooler.
wish i were in the u.k., because the coldest i've
ever experienced it on my many trips was when i was in york. it was in february and very cold.
i was sightseeing near monks bar and the temp was around 38F. not as cold as here though. can i also do a winter adjustment for the mixture for cold weather?
emanuel
maybe it was a bit colder than 38F and all the sam smith oatmeal stout that i had ingested was keeping me warm. (i had to visit tadcaster).
MGTF1250Dave
Aloha All,
Happy New Year! This is an excellent discussion.
In my opinion, the mixture adjustment is probably the last thing to check. The spring pressure on the mixture adjustment nut will probably not move without your help. Most carburetor problems I've experienced with your symptons are things like the connection between carbs is slipping so that the butterfly plates are not aligned (one closed and the other partly open), clogged inlet filter to the float bowl, and sticking float bowl valve. Ignition problems would also be a probable cause of these problems.
As Alec mentioned periodic cleaning the the dash pot and throat is important to keep it moving freely. The internal passages for air movement also need to be cleaned. These are the holes exposed when the dashpot cover and filters are removed. Pipe cleaners dipped in carb cleaner or a spray can with the extended tube work well for this. A vacuum above the dashpot is caused by air flow through the carburetor which helps it rise as you accelerate. I have also seen the air filter gasket installed upside down blocking the air passages.
Regarding the oil to use in your SU carburetor, I think you should use the same grade you use in the engine for your climate. It is important keep the oil level about 3/4 inch below the top of the dash pot tube. This allows for the damper mechanism attached to the nut. The top of the tube is about an inch below the top of the bore in the dash pot cover. I have found that a plastic carpenter glue applicator (looks like a plastic hypodermic needle) is good for filling and removing excess oil. Over filling will result in the excess oil getting all over the inside of your carburator.
Safety Fast,
Dave
X
XJRpilot
happy new year to all;
thanks dave,
when i did the winter oil change in november,
i used castrol 10w30. seems a better choice than castrol 20w50 for our cold winters here.
as soon as i get a fair weather day ( so my fingers wont freeze), i'll clean the carbs and do the "final" adjustments.
maybe the dashpot oil could be changed for the winter, and back to 20w50 for the spring and summer.
mowog
I have always used a light oil like 3 in 1 never have I heard of ppl using 20-50 until I read it here
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
G Setting mixture on HS4 carbs MG 30
S Looking for hs4 aud 135r carbs MG 10
X SU hs4 carbs and my frightened neighbors MG 9
torque-drive MGB SU HS4 jet height adjustments MG 6
G Twin HS4 Su's leaking fuel Spridgets 18
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
bugedd HS4 mixture adjustment help please Spridgets 13
H General Tech SU HS4 Carb Question Triumph 5
dklawson Hs4 Float Bowl Failure Spridgets 11
RichBall HS2 and HS4 measurment Spridgets 7
bigjones HS4 needle mystery MG 15
mikecyc72usa Spitfire Spitfire 1500, SU HS4 major issue Triumph 14
fogliner My HS4 plumbing solution MG 13
bigjones 1500 - HS4 - improvements Spridgets 3
G HS4 fixed needle or spring loaded? [which is best] Spridgets 15
G HS4 carb question Spridgets 10
Gundy HS4 plumbing Spridgets 6
bigjones HS4 - quick question MG 6
G Carb floats SU HS4 on triple carb AH BT7 Austin Healey 10
bigjones HS4 - 1500 - slight problem Spridgets 24
JPSmit Quick HS4 Question MG 2
bcbug Installing a HS4 on a 76 Midget Spridgets 12
bigjones Single HS4 on a 1500 Spridgets 25
dklawson Single HS4 Conversion Troubleshooting Triumph 6
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
JPSmit HS4 needle question MG 2
JPSmit SU HS4 question MG 3
dklawson Spitfire ZS Stromberg vs HS4 SU on 1300 Spitfire? Triumph 11
Atrus Carb velocity stacks - are these HS2 or HS4? Spridgets 2
H HS4 to HIF inlet manifold question MG 2
don62 SU HS4 head jets adjustment MG 12
T Spitfire Spitfire HS4 help Triumph 11
T HS4 and HIF4 inter-carb linkages the same? MG 10
T HS4 vs. HIF4 MG 15
Atrus 1275 intake manifolds [Weber, HS4, custom] Spridgets 6
Atrus [2] HS2 vs [1] HS4 Spridgets 10
budk1953 Need a Pic of HS4's Spridgets 8
KLUTZ Properly tuned HS4's.. are they all the same? MG 6
wkilleffer MGB HS4 carb question- 18GK engine, 1974 MGB [long] MG 6
RobSelina Air filter housing for HS4 [also need tuning help] Spridgets 21
mgblue79 1500 Midget HS4 conversion Spridgets 8
KLUTZ HS4 Spring count. MG 1
E HS4 SU carb inlet diameter? MG 15
Jay_Nickell SU HS4 Rehab MG 5
sultanoswing HS4 carb question MG 20
RobSelina anyone have .... [now HS4 linkage problem] Spridgets 5
RobSelina plumbing a single HS4 on the 1500 Spridgets 5
mylillooker SU HS4's "vs" Weber 32/36 Spridgets 5
P MGB Choke on SU-HS4 1971 MGB MG 4
