Stop/Tail light wiring
RAC68
Hi Bob/Reid,
Thanks Bob. I will use that expression in the future. Thanks Reid, the Danny Kaye short was Tickety Boo.
Ray(64BJ8P1)
twas_brillig
Regards tickety-boo: have a look-see at https://www.worldwidewords.org/qa/qa-tic1.htm
My understanding is that it was used in the RAF during WWI, having been developed from some Hindi words and brought back to Jolly Olde via the British military. I sure can't disagree with the WWII reference, but Canadians et al (as well as the rest of the colonies) had personnel with the RAF in WWI as well as independently and with the RAF in WWII. My Dad was maintenance with the Royal Canadian Air Force in Canada during WWII and retired in 1971, with the family living on military bases for quite a few years - I've used tickety-boo (everything's good; all right; no worries) for decades, as it is such a delightfully sounding phrased. Doug (PS: on less important issues: our BJ7 has the incandescent bulb kit replacing the reflectors, LEDs for the tail/brake lights; and a 4 way flasher set up using the signal lights. I would like to hear from those who've added a high-mount third brake light as even these upgrades can't offset the small size and low position of the brake lights)
B
bob hughes
Twas
I have the part as a thinnish strip light but have yet to figure how I am going to fit it, especially as I am positive earth. I have a works luggage rack on the rear and it seems like a good idea to locate it there on a plastic mount of some sort, the wiring would have to be taped to the rack, probably on the U/S and run from the top of the boot lid (trunk) to the final position on the rear of the rack. Still a work in progress.
:cheers:
Bob
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
W Xenon red LED stop/tail lamp upgrade kit Spridgets 6
K TR2/3/3A The two wires that go to the brake light stop switch junction......... Triumph 1
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
Basil Drop Stop Restoration & Tools 3
D TR4/4A rebound stop clearance issue Triumph 13
edkap2002 TR6 stop light [brake light] swith Triumph 9
O Hesitation on pulling away from stop Jaguar 25
D extra stop/brake light Austin Healey 33
steveg Wanted - easy install tool or technique for directional/stop light lenses Austin Healey 9
warwick-steve Bump stop box query Austin Healey 19
Scotsman TR4/4A Steering Stop Lock on trunnion Triumph 9
KVH TR4/4A I Can't Stop Burning Oil; Engine Missing at Take Off Triumph 5
HealeyRick Wipers Won't Stop Spridgets 6
T TR4/4A Rear Bump Stop Spacer Triumph 1
M Stop the EPA Racing 7
bugedd Rear axle bump stop Spridgets 7
K TR2/3/3A Clutch Master Cylinder "Stop" Bolt.... Triumph 4
C Bump Stop Box Color??? Austin Healey 4
maxwedge5281 braking circuit through the stop light switch Austin Healey 7
J How to put a stop on the end of a choke cable? Restoration & Tools 2
B LED bulbs as side lights/stop light/flashers Austin Healey 29
tomshobby lower window stop? Spridgets 7
Mickey Richaud MGB Rear Bump Stop - MGB MG 2
PatGalvin The fun just won't stop [engine rebuild questions] Triumph 53
drooartz Off Topic It really needs to stop snowing... MG 19
Tim Tucker TR4/4A TR4 STOP BRACKET for WINDOW REGULATOR Triumph 5
Superwrench Horns won't stop beeping ! Help ! Austin Healey 4
N Running and stop bulbs??? Spridgets 4
J POR-15 where to stop??? Spridgets 30
T She runs! She won't stop running! Triumph 2
A TR2/3/3A TR-3A door strap/stop attachment to body Triumph 10
doates Now how do I make it stop? Triumph 12
M trans leaking, any additive to stop it Austin Healey 13
Trevor Jessie Emergency Stop Spridgets 8
G Racing idle at stop lights MG 3
tr6nitjulius One Stop! In Old out New! Triumph 3
DNK And he didn't even stop! Spotted 18
G FUEL PUMP WON'T STOP CLICKING Austin Healey 12
C Stop Light Switch Spridgets 17
doates Spitfire Spit Does Not Want To Stop Triumph 12
J Starter does not want to stop Triumph 11
K TR2/3/3A TR3 stop lights lens Triumph 12
TR6oldtimer TR6 TR6 Door Stop Triumph 3
M Stop that seep Triumph 14
jdubois TR2/3/3A What's the deal on the fuel stop tap on the TR3? Triumph 4
Basil Brake Servo Cylinder Stop Pin needed Jaguar 17
Tinkerman TR2/3/3A TR3 Gas Stop Tap Needed ! Triumph 6
J Bump Stop Box Austin Healey 3
Hooper11772 OMG stop smoking already!!!! Spridgets 75
