Brake Servo Cylinder Stop Pin needed
Platinum
In the dark recesses of my pea brane there's a passing thought... needle bearing (like from a transmission layshaft)?
I'd be finding something close in diameter and make a mock-up then head to a bearing house. IIRC those pins were hardened so a needle bearing of correct diameter would work as a replacement. Length would be a lesser issue, longer than needed can be ground off.
...just a thought.
Platinum
Agree. But if one doesn't show up, it ain't likely to be a point loser. :jester:
Deleted member 8987
Hydroboost is good folks.
They do NOT do credit cards, which makes it a bummer.
I had my PBR booster rebuilt there.
Deleted member 8987
There is a guy over on jaglovers offering to make you one outta stainless.
Dave
There's a booster for CAB's?? Leave it to you Doc to have one or even know that! :laugh:
Basil, there's a couple of local sources here I can ask....I'll let you know what I find.
Deleted member 8987
Looks like the folks on jaglovers have you set for a stainless pin.
Platinum
Just keep in mind stainless is usually SOFT.
...just sayin'...
Administrator
Boss
...just sayin'...
These pics are pretty short so I don't think that will be an issue and they don't really carry a huge load.
Platinum
"Stainless" comes in all sorts of grades and hardness. Bolts/nuts aren't made from soft material. Stock the same diameter as that little PIN just may be.
This is actually a fair catalogue of the different carbon and alloy HERE.
Administrator
Boss
Well, like I said, the load on this little pin isn't tremendous. It limits the travel of a piston when the brake system is "off" and the piston is only being pushed by a return spring inside the cylinder bore, so I doubt that hardness is going to be a big issue.
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
J brake master cylinder and servo Triumph 15
M Brake Servo Austin Healey 2
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
Walter74 Brake Servo Location Austin Healey 6
R Brake Servo Rebuilder Austin Healey 14
Jeepster BJ8 Servo/ brake booster test Austin Healey 1
H BJ8 Exhaust System and Brake Servo Austin Healey 16
C TR6 Brake servo leaking Triumph 3
B Power Brake Servo for a 100 Austin Healey 3
M Orientation of Lockheed brake servo Austin Healey 2
R Healey Marque Brake Servo story Austin Healey 6
N Spitfire brake servo in a spitfire Triumph 3
S Brake Servo Installation Austin Healey 13
D TR6 Brake servo and rear tire rubbing Triumph 4
R BJ8 with servo...Brake travel issue Austin Healey 30
R Installing an aftermarket brake servo kit Austin Healey 6
S brake servo Austin Healey 3
L BJ8 Brake servo Austin Healey 6
D TR6 76 TR6 Brake Servo Triumph 2
W brake servo install? Triumph 1
W brake servo Triumph 3
W Brake fluid in Servo/booster Triumph 5
D Brake servo Austin Healey 1
Frank C. Brake Servo Replacement Austin Healey 6
T 77 with twon SU's- need to remove brake servo MG 2
John_Mc Brake/Servo issues Triumph 7
T XKE Series 2 Brake Servo Jaguar 2
B Brake Servo Parts... Triumph 1
B brake servo plumbing for BJ7 Austin Healey 8
J hints on rebuilding brake servo? Triumph 9
D brake servo Austin Healey 6
wangdango TR6 TR6 brake servo rebuild kit? Triumph 2
J Is my brake servo working? Austin Healey 5
chicken Brake servo pipe routing Austin Healey 1
RomanH Brake Servo Triumph 2
N Brake servo air filter Austin Healey 2
John_Mc Brake question. Servo? Triumph 7
A brake servo booster help Triumph 3
J Brake servo Austin Healey 4
C BJ8 brake servo options Austin Healey 5
A brake servo change out Triumph 1
N Brake Servo Lockheed Austin Healey 0
B TR6 TR6 Fuel Odor in the Brake Servo Triumph 7
J Repair of brake servo's Austin Healey 19
S BJ8 Brake Servo Replacement Installation? Austin Healey 9
J Brake Servo mounting measurements Austin Healey 3
B Brake Servo Question 62 BT7 Tricarb Austin Healey 3
V NEW old brake servo Jaguar 14
