BJ8 Brake servo
Leo_Speichinger
My servo has gone bad and so I need to replace it but I have a couple of questions. 1st, I shouldnt hear liquid in the vacum resivior should I? 2d, Has anybody used the servo ebay item # 200880381298 ? Or does anybody have another reputable source besides Moss?
Thanks
Leo
Thanks
Leo
First, you absolutely should not hear any liquid in the vacuum chamber (I'm assuming you have the servo out and you're shaking it). This means the 'gland seal' around the vacuum piston shaft has failed and is allowing brake fluid into the chamber (of course, the level of BF in the reservoir will drop rapidly).
Second, these servos can be rebuilt. You can do it yourself or send it to a servo rebuilder. I did mine, and it's been fine for 40K miles or so. It's basically a slave and a master cylinder combined, and some simple valving to control air/vacuum flow. Rebuild kits are available, and the usual suspects can sleeve the cylinders. If you'd rather install a new aftermarket one the one on eBay is a commonly-used retrofit and should work fine.
Jeepster
Get your original unit reconditioned. Then it will bolt straight back on.
The aftermarket units require a different bracket for fitment and can interfere with the oil filter.
Patrick67BJ8
Thanks
Leo
I used Power Brake Exchange to rebuild mine. They have reproduced some of the parts that you can no longer get. Turn around was quick and I think labout $300.00. Came back looking good. I believe they cleaned the airfilter but I had a new one so I installed that instead.
Lotuswins
Leo,
I second Patrick's advise. Power brake exchange is the way to go. I did my own rebuild and the kits aren't cheap, and the bores are very small, and aluminum. I went through 4 old units to find one with a good set of bores. I also hear that 50% or better of home rebuilds don't take. Then there is the fitment issue too, a new one will require fabrication.
Best of luck.
I'll second Leo's advise. I rebuilt mine during the cars restoration. It didn't work. By passed it and drove the car for about a year without one. Bought a aftermarket one, fabbed a bracket to install. I can't tell that much difference in the braking. Do feel better knowing I have one installed on the car.
Marv
Jeepster BJ8 Servo/ brake booster test Austin Healey 1
H BJ8 Exhaust System and Brake Servo Austin Healey 16
R BJ8 with servo...Brake travel issue Austin Healey 30
C BJ8 brake servo options Austin Healey 5
S BJ8 Brake Servo Replacement Installation? Austin Healey 9
LAW75 BJ8 Brake Lines Austin Healey 2
D BJ8 brake master cylinder question Austin Healey 6
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
Marvin Gruber BJ8 brake booster Austin Healey 6
wangdango BJ8 brake reservoir? Austin Healey 7
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
Bob_Spidell Brake Pads for BJ8 Austin Healey 24
Marvin Gruber BJ8 brake booster picture Austin Healey 4
Marvin Gruber BJ8 brake connectors Austin Healey 17
F Front brake hose BJ8 Austin Healey 4
F front brake hose 67 BJ8 Austin Healey 4
J Emergnecy Brake Cable Replacement BJ8 Austin Healey 4
P Brake boost repair, BJ8 Austin Healey 10
Dave Richards BJ8 Rear Brake Kit British Parts Northwest Austin Healey 4
B BJ8 Rear Brake Questions/Advice Austin Healey 4
BOBBYR BJ8 Brake Booster Austin Healey 13
R BJ8 Brake Drum Removal Austin Healey 6
C question on the front brake lines for BJ8 Austin Healey 2
P BJ8 Brake Booster mount Austin Healey 9
L Initial Adjustment of Pushrod on BJ8 Brake Master Cylinder Austin Healey 5
T Soft brake pedal on BJ8 Austin Healey 3
TRdarrel4 '66 BJ8 brake drum spec? Austin Healey 12
RAC68 BJ8 Brake/Clutch Reservoir Fluid Loss Austin Healey 14
98Redline BJ8 Stainless Braided Brake Hoses Austin Healey 8
Jeepster New BJ8 - brake caliper fouls on wheel spokes Austin Healey 3
S BJ8 rear brake drums Austin Healey 8
letemglow Brake master cylinder BJ8 Austin Healey 0
healeyneil Sticking back brake BJ8 Austin Healey 0
J BJ8 brake light not working? Austin Healey 2
C BJ8 brake fluid disappearing Austin Healey 11
J Late BJ8 brake rotor- thickness specs Austin Healey 5
WALTER BJ8 w/o brake booster? Austin Healey 4
J BJ8 Brake Booster Austin Healey 5
C AH3000 BJ8 Brake Caliper question Austin Healey 7
R 67 BJ8 Brake Light Switch Austin Healey 2
R 67 BJ8 Brake Fluid Resivor Austin Healey 6
R BJ8 brake calipers Austin Healey 14
S BJ8 Emergency Brake Lever Loose Austin Healey 1
D brake light problem 67 BJ8 Austin Healey 4
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
