BJ8 rear brake drums
shorn
Can anyone tell me the specs for the rear brake drums on a BJ8 (probably the same as earlier models). Not sure how many times mine have been turned and it is almost impossible to adjust properly with new linings.
BoyRacer
Your BJ8 drums are the same as all of the earlier drums. I would give you odds that your drums have never been turned - I assume you did not have them turned. Did you have your newly lined shoes matched to the curvature of your drums? If not, that may be your problem.
Brinkerhoff
MG TF 1500 value?
I have a chance to an MG TF with the 1500 in it. Its a clean unrestored car with orig. drivetrain and interior , hard to tell about the paint . What's the market like for this car? Thanks, Kevin
S
shorn
Re: MG TF 1500 value?
still looking for what the diameter measurement should be on a new BJ8 rear brake drum, it anyone knows.
Grantura_MKI
A 1500 is the one to have. The price depends on many things...body timbers, original wings and numbers of motor and trans, etc. Many items can be switched out with TD bits.
BoyRacer
The drum diameter is 11 inches.
John_Progess
Brinkerhoff,
A nicely restored TF 1500 should fetch about $35000. An original car could be worth more depending on condition. Be sure it is an original 1500 engine, not just any 1500 but a TF 1500 as this engine is particular to this car only. The engine number is on a brass octagon tag on the right side of the engine. It should be an XPEG not an XPAG engine. Check that the numbers match the tag on the firewall. The number is also stamped on the left dumb iron that supports the front bumper. Hope this helps and have a good day!
John
Dave Richards BJ8 Rear Brake Kit British Parts Northwest Austin Healey 4
B BJ8 Rear Brake Questions/Advice Austin Healey 4
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
crispy BJ8 Rear Seat Back Upholstery Hardware Austin Healey 7
J BJ8 Rear Seat Changes, 1964 to Later Austin Healey 9
S BJ8 Rear Seat Side Panels Austin Healey 3
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
AUSMHLY Squeak from rear of BJ8 Austin Healey 51
S Wanted Rear Seat Slide Bolts, BJ8 Austin Healey Classifieds 0
C For Sale 67 BJ8 rear trunk luggage rack- Austin Healey Classifieds 0
G rear wheel studs on my 1967 BJ8 Austin Healey 5
AUSMHLY BJ8 rear axle oil seal Austin Healey 6
RickPA BJ8 rear wheel cylinder install Austin Healey 1
B BJ7 & BJ8 Interior Rear Quarter Panels Austin Healey 12
J BJ8 rear main seal kit - is it necessary and worth the risk to install? Austin Healey 33
J BJ8 early P2 rear spring mystery - what do I have. Austin Healey 6
J Rear axle noises==BJ8 Austin Healey 7
B Rear view mirror location for BJ8 Austin Healey 14
Jeepster BJ8 rear leaf springs Austin Healey 2
L BJ8 Rear Interior panel fitting Austin Healey 7
C BJ8 Rear Seat Back Carpeting? Austin Healey 3
L 1966 BJ8 rear trim panels Austin Healey 8
J Rear Axel/Bearing & Axle Seal.\ BJ8 . Austin Healey 5
P BJ8 phase 2 rear leaf springs Austin Healey 2
pkmh Removing Rear Hub on BJ8 Austin Healey 48
M looking for rear end gears for bj8 Austin Healey 25
A BJ8 Rear Drum removal Austin Healey 8
Jeepster BJ8 rear seats Austin Healey 12
AUSMHLY BJ8 Rear Trim Rail Austin Healey 34
B BJ7 & BJ8 soft top rear seal Austin Healey 2
L BJ8 dome nuts on rear interior panel Austin Healey 5
6 Need help with BJ8 rear shock position Austin Healey 2
6 BJ8 Rear Shock Installation Austin Healey 1
Johnny Help Identify BJ8 rear mufflers Austin Healey 14
B AH BJ8 REAR SPRING INSTALLATION Austin Healey 5
B 3000 [not BJ8] Rear Springs - too stiff - why? Austin Healey 6
S BJ8 Rear Seats Austin Healey 7
J BJ8 rear boot floor replacement. Austin Healey 9
S Rear springs - BJ8 Austin Healey 1
AUSMHLY BJ8 rear wheel well gap size Austin Healey 17
A BJ8 Rear Seat slide bolts Austin Healey 1
A Tinkling rear brakes [BJ8] Austin Healey 5
H Rear springs BJ8 Austin Healey 7
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
